Convergence of sequences of functions with differing domains?
In summary, the convergence of sequences of functions with differing domains refers to the behavior of a sequence of functions as its input values approach a limit. This concept is important in the study of mathematical analysis and helps to determine the behavior of functions in various settings. Convergence can occur in different ways, such as pointwise convergence, uniform convergence, and norm convergence, and the type of convergence can depend on the properties of the functions and their domains. Understanding the convergence of sequences of functions is crucial in many areas of mathematics, including calculus, differential equations, and topology.
Stephen Tashi
1,599
TL;DR Summary
Is there a type of convergence defined for sequences of functions that have different domains?
Of the various notions of convergence for sequences of functions (e.g. pointwise, uniform, convergence in distribution, etc.) which of them can describe convergence of a sequence of functions that have different domains? For example, let ##F_n(x)## be defined by ##F_n(x) = 1 + h## where ##h = 1/n## and F_n(x) has the domain ##\{h,2h,3h,..1\}## Intuitively, the sequence of functions ##F_n, n = 1,2,3,...## converges to the function ##F(x) = 1## defined on ##(0,1]##.
Which definitions handle the above type of convegence without assuming the definition of each function in the sequence is extended to have the same domain as the function that is the limit? ( For example, for convergence in ##L_2## we could stipulate that the domain of each ##F_n(x)## is extended to ##(0,1]## by defining ##F_n(x)## to be a step function over intervals ##(kh, (k+1)h)## Then the same notion of integration would apply to both ##F_n(x)## and ##F(x)##. Can we avoid making such stipulations?)
Convergence is a topological term. So if you have another topological space for each function, convergence makes no sense.
But your functions do not depend on the variable, so their domain is ##\mathbb{R}## and all functions are in ##C^\infty(\mathbb{R})## converging to ##1##.
I agree we can define new functions by extending the domain of the functions in the example, but the domain of a function ##F_n## is given in it's definition. For example, nothing in the definition of ##F_2(x)## says that ##F_2## can be evaluated at ##x = 1/10##.
To make an example using non-constant functions, Define ##G_n(x) = x^2 + h ## for ##h = 1/n## and ##x \in \{h,2h,3h,...1\}##.
Doesn't matter, you cannot define convergence across different spaces.
That suggests considering the graphs of ##F## and ##F_n## each to be subsets of the metric space ##\mathbb{R}^2##. So one aspect of the convergence of ##F_n## to ##F## can handled by the a definition for what it means for a sequence of sets to converge to a set.
In this case you have to define a metric on ##\mathcal{P}(\mathbb{R}^2)## or define a topology otherwise which allows you to define "nearby". Maybe the concept of nets is what you were looking for.
I found this paper:
https://projecteuclid.org/download/pdf_1/euclid.rae/1229619414
ON THE GRAPH CONVERGENCE OF SEQUENCES OF FUNCTIONS
by Zbigniew Grande
Let ##(X,T_X)## and ##(Y,T_Y)## be topological spaces and let ##\mathbb{R}## be the set of all reals considered with the natural topology ##T_e##. Denote by ##T_X \times T_Y## the product topology in ##X×Y##. We will say that a sequence of functions ##f_n:X→Y## graph converges to a function ##f:X→Y## if for each set ## U∈T_X×T_Y## containing the graph ##Gr(f)## of the function ##f## there is a positive integer ##k## such that ##Gr(f_n)⊂U## for all ##n k##.
I think "##nk##" is a misprint for ##n>k##.
That definition is relevant to the OP if the notation "##f_n:X \rightarrow Y##" allows that the domain of ##f_n## might be a proper subset of ##X## and the co-domain might be a proper subset of ##Y##.
It's interesting that meaning of "##Gr(f)##" is taken to be self-evident. (I assume "graph of a function" in this context is a separate concept from "graph" as studied in Graph Theory. )
The graph of a function ##f:\mathbb{R}\to \mathbb{R}## is the set ##\{(x,f(x))\,|\,x\in D\subseteq \mathbb{R}\}## with domain ##D##. It's a subset of ##\mathbb{R}^2##. You can have convergence on this set, here as the Euclidean product topology. In this sense your graphs converge. It's another question whether this is useful for anything. You have a lot of artificial gaps, so I can't see how this could be useful.
In case your functions are linear operators on complex Hilbert spaces, this type of convergence is called graph convergence. (At least in my book.) They are useful in case of self adjoint operators. However, in this case we have a sequence of functions and a sequence of operators such that ##(f_n,T_nf_n)\to (f,g).##
Likes etotheipi
I'm considering questions about when a sequence of solutions to recurrence relations defined on smaller and smaller intervals will converge to a unique function defined everywhere on some subinterval of the reals. Since the solutions to recurrence relations are (in general) only defined on discrete values ##{h, 2h, 3h,...}## a notion of convergence of a sequence of functions is needed that applies to this case.
I'll have to think about whether operators bear on the topic of recurrence relations. Anyway, the recurrence relations are a topic for a different thread.
The definition given by Zbigniew Grande (ZB) defines convergence for sequences of graphs of a function to a graph of a function. It doesn't define the more general notion of the convergence of sequences of graphs of a function to a set S (which may or may not be the graph of a function). Using ##S## to denote a subset of ##T_x \times T_y##, we can generalize ZB's definition to define what it means for ##S## to be the limit, by using ##S## in place of ##Gr(f)##. I'll call this generalization a "Generalized Zibigniew Grande Limit" (GZGL)Natural questions about that generalization about GZGLs are
1. If a GZGL exists, is it unique?
2. If the GZGL limit of sequence of functions exists, is that limit also a function?
I think the paper answers "yes" to both questions in the case of ##X = \mathbb{R}## and ##Y = \mathbb{R}## since it gets those results in the cases where the product topology is "T 1" and Hausdorff.
Think about your first example. Let's define ##g(x)=f(x)\equiv 1## with ##D(f)=[0,1]## and ##D(g)=[0,1]\cap \mathbb{Q}##. Then we have two different limits.
Likes Stephen Tashi
I see what you mean.
The Zibigniew Grande paper is assuming each ##f_n## has domain ##X##. This is clear from the proof of Theorem 1, which assumes ##f_n(x)## exists for each ##x## where ##f(x)## exists. So the paper isn't relevant to what I want.
The notions of "inner limit" and "outer limit" for sequences of sets ( https://en.wikipedia.org/wiki/Limit_superior_and_limit_inferior#General_set_convergence ) apply to the sequence ##Gr(f_n)## without the assumption that the domain of ##f_n## is all of ##X##.
If you have a recursive system, there is another approach you could try: changing the system into differential equations. The standard here is the other way around, from diff systems to numerical difference and recursion systems, but IIRC it is also possible to go from discrete to smooth.
Here is another interesting list of possibilities:
https://en.wikipedia.org/wiki/Recurrence_relation
Related to Convergence of sequences of functions with differing domains?
1. What is the definition of convergence of sequences of functions with differing domains?
The convergence of sequences of functions with differing domains refers to the behavior of a sequence of functions as the independent variable approaches a certain value or goes to infinity. In other words, it describes how the functions in the sequence approach a specific function as the input values get closer and closer to a particular value.
2. How is the convergence of sequences of functions with differing domains determined?
The convergence of sequences of functions with differing domains is determined by evaluating the limit of the functions as the input values approach a specific value. If the limit exists and is equal to a specific function, then the sequence of functions is said to converge.
3. What is the difference between pointwise and uniform convergence of sequences of functions with differing domains?
Pointwise convergence of sequences of functions with differing domains means that for each point in the domain, the corresponding values of the functions in the sequence converge to the same value. On the other hand, uniform convergence means that the functions in the sequence converge to the same function on the entire domain, not just at specific points.
4. What are some examples of sequences of functions with differing domains that converge?
Some common examples of sequences of functions with differing domains that converge include polynomial functions, trigonometric functions, and exponential functions. For instance, the sequence of functions f(x) = x^n, where n is a positive integer, converges to the function f(x) = 0 as x approaches 0.
5. How is the convergence of sequences of functions with differing domains useful in real-world applications?
The concept of convergence of sequences of functions with differing domains is essential in various fields of science and engineering, such as physics, economics, and computer science. It allows us to approximate complex functions with simpler ones, making it easier to analyze and solve problems. It also helps in understanding the behavior of systems and predicting their future states.
  • Topology and Analysis
