Convergence of series (Theoretical Question)
In summary: I can't conclude nothing using the geral criterion of comparison cause it only applies to series with positive terms.
Muradean
1. The problem:
Ive been all afternoon struggling with this doubt. Its a bit more teoric than the rest of the exercices i did and i just can't seem to get around it so here it goes :
Consider ∑ 1/an a convergent serie of positive terms.
What´s the nature of Σ (-1)^n/(an^(2) +1)
(Leibniz criterion) ? If ∑(-1)^(n)an is an alternated serie and the sucession(an) is decreasing and his limit→+00 an = 0 then i can say that ∑(-1)^(n)an is converging.
My initial thought was:... a-ha! This is an alternate serie! Because of the (-1)^n ...
So if i prove that the serie 1/an is decreasing since i already know the lim an= 0 i can say that the serie:
(Leibniz criterion)
Σ (-1)^n/(an) IS CONVERGENT however i have two problems...1- I don't know how to prove that 1/an is decreasing.
2- The serie that they ask me to study is different and even if i could prove that 1/an is decreasing i don't know if through algebric manipulation i could get to:
Im not even sure if I am going the right way. Anyone has any clue? This is bothering me so much!atement, all variables and given/known data
Muradean said:
1. The problem:
Given that ##\sum \frac 1 {a_n}## is a convergent series with ##a_n > 0##, can you say something about the series ##\sum \frac 1 {a_n^2 + 1}##?
Are the terms of this series larger, smaller, or the same as, term by term, of the series ##\sum \frac 1 {a_n}##?
(Leibniz criterion)Σ (-1)^n/(an) IS CONVERGENT however i have two problems...1- I don't know how to prove that 1/an is decreasing.
The terms start in n= 1 and go up to +00
Fine. Did you read my post?
Oh sorry. yes i did, i notice that the terms are smaller. Are you saying that i can compare the serie
Σ 1/(an^(2) +1) with (1/an) using the criterion of geral comparison?
If an≤bn for n ≥ f then:
(1) -Σbn is convergent → Σan is convergent
(2) -Σan is divergent → Σbn is divergent
At a first glance it doesn't seem that useful cause since the terms are smaller i get that Σ 1/(an^(2) +1) is (an) and that 1/an is (bn).
So i guess now i can say that Σ 1/(an^(2) +1) is convergent?
However that serie that I am trying to prove doesn't have just positive terms, Σ (-1)^n/(an^(2) +1) also has negative terms so i can't apply criterion of comparison. So i have no clue...
Yes.
If you know that a series ##\sum b_n## converges, can you conclude anything about the alternating series ##\sum (-1)^nb_n##? I.e., does it
a) converge,
b) diverge, or
c) is it impossible to determine?
I can't conclude nothing using the geral criterion of comparison cause it only applies to series with positive terms. The problem is that (-1)^n !
Im almost sure it converges but on the definition of this criterion it says it is explicitly for series with positive terms.
I have this example in my head: Σ(1/n)
1/2,1/3,1/4,1/5 1/6...
If i join that (-1)^n it will be something like:
1/2,-1/3,1/4,-1/5 1/6... which also converges but using a example obviously in no valid explanation.
I also noticed that 1/an looks like a dirichlet series however i can't also make that assumption! cause the "(an)" can be anything! If i could I am almost sure i knew how to do it.
is it valid to do something like this?
1) Σ(-1)^n/(an^(2) +1) =( -1)^nΣ(1/(an^(2) +1)
2) since i know 1/an is a serie of positives terms larger than Σ(1/(an^(2) +1) and 1/an is convergent , Σ(1/(an^(2) +1) is also convergent.
3)Since Σ(1/(an^(2) +1) is convergent, ( -1)^nΣ(1/(an^(2) +1) also is (just cause? ).
At the risk of gving too much away,
I know that if (bn) converges, (an) will also converge. So i know that Σ(1/(an^(2) +1) is convergent, However my problem is that the serie in question is Σ((-1)^n/(an^(2) +1) and since it has negative terms i can't apply that criterion. The same applies with bn. If i know bn is convergent what criterion should i use to consider bn(-1)^n also convergent?
What is on my mind is: If i know that a certain serie is convergent, the limit →+00 = 0 and it doesn't seem to change if just multiply it by (-1)^n
Forget everything except that there is a series with terms ##b_n##, and that the series ##\sum b_n## converges. What can you conclude?
I can conclude that bn limit →+00 = 0 and that an is convergent.
Go right back to basics. If ##b_n > 0## and ##S =\sum b_n## is convergent. By definition, this means that
[tex] S(N) = \sum_{n=1}^N b_n [/tex]
is a convergent sequence; that is, ##S = \lim_{N \to \infty} S(N) ## exists and is finite. Note that
[tex] \sum_{n=1}^N b_n = \sum_{n \leq N \;\text{even}} b_n + \sum_{n \leq N \;\text{odd}} b_n . [/tex]
Ok! i think i got it. Can anyone just say if this sounds like a reasonable answer?
They ask me to study nature of ∑(-1)^n/(an^(2) + 1) knowing that 1/an is convergent.
Step 1- I know that ∑(1/(an^(2) + 1) < 1/an .
Step 2- Since all the terms of the series in Step 1 are positive i can conclude by the criterion of geral comparison that since 1/an is convergent ∑(1/(an^(2) + 1) is also convergent.
Step 3- Consider bn = ∑(1/(an^(2) + 1) so
∑bn*(-1)^n = ∑(-1)^n/(an^(2) + 1)
According to leibniz criterion, if ∑ bn*(-1)^n is an alternate serie where the sucession bn is decreasing and convergent and its lim+00 = 0.(basically saying that bn must be convergent)
I can conclude that ∑ bn*(-1)^n = ∑(-1)^n/(an^(2) + 1) is convergent!
Muradean said:
Nevermind, i just check the Leibniz criterion again. If bn is convergent, its lim+00 = 0.
And according to Leibniz criterion:
if Σ(-1)bn is an alternated serie where the sucession (bn) is decreasing and its lim+00 = 0 then i can say that Σ(-1)^nbn is convergent.
I can come up with a sequence in which the ##b_n>0 ## are not monotone non-increasing, but which go to zero quickly enough that the series ##\sum b_n## converges anyway. You could not apply your argument to such a case.
Your Step 1 is wrong; you may have ##1/(a_n^2 +1) < 1/a_n## but there is no reason at all to assume you have ##\sum 1/(a_n^2 +1) < 1/a_n##. When you write things like that you are just begging for marks to be taken off!
Anyway, as I said before, you cannot just apply an alternating-series argument, because the successive terms may not be decreasing each and every time.
Sorry, I've been reviewing the steps and what i really meant to write as Step 1 was :Step 1- I know that (1/(an^(2) + 1) < 1/an . (i bugged the integral symbol on the previous post)
Step 2- Since Σ1/an and ∑(1/(an^(2) + 1) have just positive terms i can conclude by the criterion of geral comparison that since ∑1/an is convergent ∑(1/(an^(2) + 1) is also convergent.
I can conclude that ∑ bn*(-1)^n = ∑(-1)^n/(an^(2) + 1) is convergent!Note:Since bn is convergent can't i tell by D`Alembert criterion that if i do lim n->+00 bn+1/bn = <1 and so... doesn't this mean that bn is decreasing?
No. Consider an example like ##b_n = |\sin(n)|/n^{1.1}##. We have ##b_n \leq 1/n^{1.1}##, so ##\sum b_n## is dominated by the convergent ##p##-series ##\sum 1/n^{1.1}##, but the terms of ##b_n## do not form a non-decreasing sequence: we can have ##b_{n+1} > b_n## for infinitely many values of ##n##. Nevertheless, we can establish the convergence of ##\sum (-1)^n b_n##, essentially using the hints I supplied in post #12.
I´ve read and spent some time with post 12, but i just don't see how it does prove the convergence of ∑(-1)^nbn, could you provide me with any hint?
Try writing out the first six or seven terms of both the finite sums ##\sum_{n=1}^N b_n## and ##\sum_{n=1}^N (-1)^n b_n##, then look carefully at what you have. It is important to remember that for finite sums it is perfectly legitimate to re-order the terms and collect them in any convenient forms you want.
Related to Convergence of series (Theoretical Question)
1. What is the definition of convergence of a series?
The convergence of a series refers to the property of a series where the sum of its terms approaches a finite value as the number of terms in the series increases.
2. How do you determine if a series converges or diverges?
There are several tests that can be used to determine the convergence or divergence of a series, such as the ratio test, comparison test, and integral test. These tests compare the given series to a known series with known convergence or divergence properties.
3. What is the difference between absolute and conditional convergence?
Absolute convergence refers to a series where the sum of the absolute values of its terms converges, regardless of the order of the terms. Conditional convergence refers to a series where the sum of its terms only converges when the terms are arranged in a specific order.
4. Can a divergent series have a finite sum?
No, a divergent series does not have a finite sum. The sum of a series must approach a finite value in order for it to be considered convergent.
5. How does the convergence of a series relate to the behavior of its terms?
The convergence of a series is directly related to the behavior of its terms. If the terms of a series decrease in value as the series progresses, the series is more likely to converge. However, if the terms increase or do not have a clear trend, the series is more likely to diverge.
