Convergence on [-M,M] for any M implies convergence on R?
  • Thread starter Thread starter timon
    Convergence
The discussion revolves around the continuity and differentiability of the series h(x) = ∑(1/(x²+n²)). It is established that h(x) is continuous on R using the Weierstrass M-test for uniform convergence. The inquiry then shifts to whether h(x) is differentiable and if its derivative h'(x) is continuous. The manual suggests that uniform convergence on any interval [-M, M] implies uniform convergence on R, as M is arbitrary. Confusion arises regarding the classification of R as a closed interval, with clarification that R is unbounded but still closed in terms of convergence properties.
timon
Good day dear fellows. I am given the following series
h(x) = \sum_{n=1}^{\infty} \frac{1}{x^2+n^2}.
It is requested that I show that h(x) is continuous on R. I did the following: use the Weirerstrass M-test to show uniform convergence, and then, using the continuity of the functions that are being summed, conclude that h(x) is continuous. The solutions manual agrees with me. So far so good.
Next I am asked whether h(x) is differentiable, and, if h(x) is differentiable, to investigate if the derivative h'(x) is continuous. I note that that
\frac{d}{dx} \frac{1}{x^2+n^2} = \frac{-2x}{(x^2+n^2)^2}.
At this point I don't see how I am going to get uniform convergence out of a summation over this thing, so I take out the solutions manual again. The manual uses the Weirerstrass M-test to show uniform convergence on [-M,M] for arbitrary M, and concludes that there must be uniform convergence on R (because M is aribitrary). To be explicit: on any interval [-M,M],
|\frac{2x}{x^2+n^2} | \leq \frac{2M}{n^2}.
(the square over the denominator can be removed since the denominator is greater than one).
And, since
\sum_{n=1}^{infty} \frac{2M}{n^2}
converges on [-M,M], uniform convergence of the derivatives follows via the weirerstrass M-test. Since M is arbitrary, we then have uniform convergence (and thus continuity) on R.
I don't see how this is so, since R is not a closed interval..
On the contrary, R is a closed interval. It is just not a bounded interval.
In any case, "convergence", in a set X, just means the series converges at every point of X. Let p be any point in R. Then there exist M such that -M< p< M. If the series converges on [-M, M] then it converges at p. Since p could be any point in R, the series converges for all R.
"Uniform convergence" would be a different matter.
I think I am confused by the notation for intervals. For any finite numbers a and b, (a,b) is an open interval, and every closed interval can be written [c,d], where c and d are its endpoints. But this isn't true for unbounded intervals? In other words, (-\infty, \infty) is a closed interval, since it contains all it's limit points (but not its endpoints)? Endpoints of unbounded intervals are not limit points?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
