Convergent sequences might not have max or min
In summary, the conversation discusses the question of whether both a max and a min exist for a convergent sequence. A counterexample is provided and it is proven that the sequence does not have a minimum. The conversation then goes on to discuss whether there can be an example where both a max and min fail to exist, and a possible proof is provided for this statement.
Mr Davis 97
1,462
44
Prove or produce a counterexample: If ##\{a_n\}_{n=1}^\infty\subset \mathbb{R}## is convergent, then
\min (\{a_n:n\in\mathbb{N}\} )## and
##\max (\{a_n:n\in\mathbb{N}\} )
both exist.
I will produce a counterexample.
Let ##a_n = \frac{1}{n}##. First we will show that ##a_n## is converges to 0.
Let ##\epsilon > 0##. By the Archimedian principle there exists an ##N \in \mathbb{N}## such that ##\frac{1}{N} < \epsilon##. If ##n \ge N##, then ##|a_n - 0| = |\frac{1}{n} - 0| = \frac{1}{n} \le \frac{1}{N} < \epsilon##. So ##\lim a_n = 0##.
Let ##S = \{\frac{1}{n}:n\in\mathbb{N}\}##. Then ##\max(S) = \sup(S) = 1##. However, the set does not have a minimum, and this is where I'm stuck. Do I need to show that ##\inf(S) = 0## and that ##0 \not \in S##? Clearly there is no minimum, but I am not sure how to show this rigorously.
Yes, it is sufficient to show that inf(S) = 0 but inf(S) does not belong to S.
This works. Now, what simple thing can you do to provide an example for the other assertion?
Since the question asked whether both a max and a min exist, he has disproved that by showing there need not be a min. A similar example could be given about the max.
However, a more interesting (and seemingly much harder) case is whether one can find a single example in which both a max and a min fail to exist. (In other words, must every convergent sequence have either a max or a min?)
Likes Mr Davis 97
I'm actually not sure how to show that ##\inf(S) = 0##. Does it go something like this?
1) 0 is a lower bound. Since clearly ##\forall n \in \mathbb{N}##, ##0 \le \frac{1}{n}##.
2) Let ##b## be a lower bound for ##S##. Then ##\forall n \in \mathbb{N}##, ##b \le \frac{1}{n}##... This is where I'm stuck. I don't see how to conclude ##b \le 0##.
One way of seeing is that since 0 is the limit, points must ultimately become indefinitely small. If {1/n} had a minimum >0 then...
There is more than one way:
(1) ##(1/n)_n## is a monotone decreasing bounded sequencce. Hence, it converges to its infinum by the monotone convergence theorem. But ##\lim_n 1/n = 0##. It follows that the infinum must be 0.
(2) Clearly, ##0 \leq 1/n## for all n. Hence, ##0## is an upper bound of the set. Use the archimedian property to show that ##0## is also the least upper bound.
My intuition tells me that your last statement is true.
Let me try to give a proof. Since our sequence ##(a_n)## is convergent, it is bounded. For the sake of reaching a contradiction, assume the sequence has neither a max nor a min. Put $$R:= \{a_n\mid n\}$$
Define ##m:= \inf R, M:= \sup R ##, which exist by boundedness of the sequence.
We can find subsequences converging to both ##m## and ##M## (this needs justification using that ##m,M \notin R##)
Because our sequence is convergent, it follows that ##m=M##. This means that R is a singelton, which means R contains its maximum and minimum.
Contradiction.
Related to Convergent sequences might not have max or min
What is a convergent sequence?
A convergent sequence is a sequence of numbers that approaches a single limit as the number of terms increases.
Why might a convergent sequence not have a maximum or minimum value?
A convergent sequence may not have a maximum or minimum value because it approaches a limit, but does not necessarily reach it. In other words, the sequence may continue to approach the limit without ever actually reaching it.
What is the difference between a maximum/minimum value and a limit?
A maximum/minimum value is the highest/lowest value in a set of numbers, while a limit is the value that a sequence approaches as the number of terms increases. A maximum/minimum value is a specific value, while a limit is a concept that describes the behavior of a sequence.
Can a convergent sequence have more than one maximum or minimum value?
No, a convergent sequence can only have one maximum and one minimum value. This is because a convergent sequence can only approach one limit.
How do you determine if a convergent sequence has a maximum or minimum value?
To determine if a convergent sequence has a maximum or minimum value, you can graph the sequence or use the limit definition. If the sequence approaches a specific value as the number of terms increases, then that value is the maximum or minimum value. If the sequence does not approach a specific value, then it does not have a maximum or minimum value.
