Convergent Series Can Be Bounded by Any ##\epsilon>0##
In summary, given a convergent series with positive terms, we can always find a natural number ##n## such that ##\sum_{k=n+1}^{\infty} a_k < \epsilon## for any given ##\epsilon > 0##. This is because the partial sums are bounded and can be made arbitrarily small by choosing a sufficiently large starting index.
Bashyboy
1,421
Assume that ##a_k > 0## and ##\sum_{k=0}^\infty a_n## converges. Then for every ##\epsilon > 0##, there exists a ##n \in Bbb{N}## such that ##\sum_{k=n+1}^\infty a_k < \epsilon##.
Since the series converges, the sequence of partial sums must be cauchy. Hence, given ##\epsilon > 0##, there exists an ##N \in \Bbb{N}## such that ##|\sum_{k=1}^m a_n - \sum_{k=1}^n | < \epsilon## for every ##n,m \ge N##. Letting ##n \ge N## and ##m = n + p##, where ##p \in \Bbb{N}## is arbitrary, we get ##|\sum_{k=1}^{p} a_{n+k} | < \epsilon## or ##\sum_{k=1}^{p} a_{n+k} < \epsilon## since the sequence is positive. Since this holds for every ##p##, the partial sums are bounded and therefore the series converges to a number less than ##\epsilon##; i.e.,
$$\sum_{k=n+1}^{\infty} a_k < \epsilon$$
How does that sound?
"Every element in the sequence is smaller than ϵ" is not sufficient to show that the limit is smaller than ϵ.
You don't need the Cauchy criterion, you can directly compare the partial sum to the limit. Alternatively, think about 2ϵ or ϵ/2 somewhere.
Likes Bashyboy
You are right. I should have begun with ##\frac{\epsilon}{2}##, and then my last line would have read "##\sum_{k=n+1}^{\infty} a_k \le \frac{\epsilon}{2} < \epsilon##."
FAQ: Convergent Series Can Be Bounded by Any ##\epsilon>0##
What is a convergent series?
A convergent series is a mathematical series where the sum of its terms approaches a finite value as the number of terms increases.
How can a convergent series be bounded by any ##\epsilon>0##?
This means that for any positive number, no matter how small, there exists a point in the series where the sum of the terms will be within that range. In other words, the series will eventually get close enough to a finite value that it can be bounded by any positive number.
Can you give an example of a convergent series?
One example of a convergent series is the geometric series, where each term is a constant multiple of the previous one. For example, 1 + 1/2 + 1/4 + 1/8 + ... is a convergent series with a sum of 2.
What does it mean for a series to be unbounded?
A series is unbounded if the sum of its terms does not approach a finite value as the number of terms increases. This means that no matter how large the number of terms, the sum will continue to increase without limit.
How is the concept of bounding a convergent series useful in mathematics?
The ability to bound a convergent series by any positive number is useful for proving the convergence of a series, as well as for approximating the value of the sum. It also allows for the evaluation of infinite series, which have important applications in various fields, including physics and engineering.
