MHB Converging Geometric Series with Negative Values?
In a decreasing geometric series, the ratio q must be between 0 and 1 for the series to converge when all terms are positive. If the terms are not all positive, the series can either consist entirely of negative values or alternate in sign. In the case of all negative terms, the negative can be factored into the first term, while alternating series can be expressed with a negative ratio. The convergence condition for a geometric series is that the ratio must satisfy -1 < r < 1. Thus, the behavior of the series changes significantly based on the sign and value of the ratio.
Lancelot1
Hiya everyone,
Alright ?
I have a simple theoretical question. In a decreasing geometric series, is it true to say that the ratio q has to be 0<q<1, assuming that all members of the series are positive ? What if they weren't all positive ?
Thank you in advance !
Mathematics news on Phys.org
A "geometric series" is of the form \sum ar^n= a+ ar+ ar^2+ ar^3+ \cdot\cdot\cdot= a(1+ r+ r^2+ r^3+ \cdot\cdot\cdot) so, yes, if the series is decreasing and positive then r must be less than 1. If r> 1 then 1&lt; r&lt; r^2&lt; r^3&lt; \cdot\cdot\cdot. If r< 1 then 1&gt; r&gt; r^2&gt; r^3&gt; \cdot\cdot\cdot. Of course, in the first case, r> 1, the series does not converge.
If they are not all positive then either they are all negative and we can take the negative into the "a" term so that \sum at^n= a\sum r^n has a negative number times the same sum of ar^n or they are alternating, \sum a(-r)^n= a\sum (-1)^n r^n. The geometric series \sum ar^n converges if and only if -1&lt; r&lt; 1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
