Converging nozzle temperature difference - Steady flow energy equation
In summary, the individual is preparing for a masters in nuclear energy and has been revising for the course by working through 15 revision questions. They have posted a question on a forum and received help in solving a question regarding a converging nozzle and the calculation of temperature at the exit. The correct answer is 15.1°C.
Nuclear_eng
I come from a civil engineering background and I'm about to start a masters in nuclear energy. I have no experience in thermodynamics and I've been doing a bit of revision before the course commences to get me up to speed. I've been working my way through 15 revision questions and I only have a couple left now. I posted a question on this forum yesterday but I'm stuck again with a different type of question on flow processes. This is meant to be one of the easiest questions in my revision booklet but so far the answer has eluded me.
A converging nozzle is used to accelerate a flow of air from 50m/s at the inlet to 150m/s at the exit. The air temperature is 25°C at the inlet. Assuming heat transfer to the air is negligible, use the steady flow energy equation to calculate the temperature at the exit.
Steady flow energy equation:
h1+0.5V12+gZ1=h2+0.5V22+gZ2
I've revised control volume analysis and steady flow processes but I'm not getting anywhere with this. I assume it will be a very simple calculation as all the other 'easy' revision questions have taken me about a minute or two.
Is there no one who can help me? I've been looking at this similar question I found on the forums and I can't get 184°C by using the SFEE. I think I must be making a mistake with the units or something really stupid.
https://www.physicsforums.com/showthread.php?t=249494
Could somebody please just plug the numbers in and show me how he got 184°C? I would imagine it will take less than a minute and it would be a massive help to me.
Thanks
Use the energy equation you have above. The enthalpy is Cp*T. Ensure you get the units correct on the V^2/(2g) term.
15.1 C is indeed correct.
Thank you very much Lawrence. I was getting my units for Cp messed up but I've now managed to get 15.1°C.
, but I'm not sure how to get there using the steady flow energy equation. Can anyone provide some guidance or a step-by-step solution?
I understand your frustration with this problem and your desire to fully understand the concept before starting your masters in nuclear energy. The steady flow energy equation is a fundamental equation in thermodynamics and understanding it is crucial for many applications, including in nuclear energy.
First, let's break down the equation. The steady flow energy equation is a statement of energy conservation for a fluid flowing through a control volume. In this case, the control volume is the converging nozzle. The equation states that the total energy at the inlet (represented by h1, the enthalpy) plus the kinetic energy and potential energy at the inlet (represented by 0.5V12 and gZ1, respectively) is equal to the total energy at the exit (represented by h2) plus the kinetic energy and potential energy at the exit (represented by 0.5V22 and gZ2, respectively).
Now, let's apply this equation to the problem at hand. We know that the inlet velocity (V1) is 50m/s and the exit velocity (V2) is 150m/s. We also know that the inlet enthalpy (h1) is equal to the air temperature (T1) at the inlet, which is 25°C. However, we don't know the exit enthalpy (h2) or the potential energies (Z1 and Z2).
To solve for the exit enthalpy (h2), we need to use the ideal gas law, which states that the enthalpy of an ideal gas is only a function of its temperature. Therefore, we can use the ideal gas law to calculate the exit enthalpy (h2) based on the exit temperature (T2).
Once we have the exit enthalpy, we can plug in all the known values into the steady flow energy equation and solve for the exit temperature (T2). This should give us the correct answer of 15.1°C.
In summary, the key to solving this problem is understanding the steady flow energy equation and using the ideal gas law to relate temperature to enthalpy. I hope this explanation helps and best of luck in your studies!
Related to Converging nozzle temperature difference - Steady flow energy equation
1. What is a converging nozzle temperature difference?
A converging nozzle temperature difference refers to the change in temperature that occurs in a fluid passing through a converging nozzle. This is caused by the conversion of pressure energy to kinetic energy, resulting in a decrease in temperature.
2. How is the temperature difference calculated?
The temperature difference in a converging nozzle can be calculated using the steady flow energy equation, which takes into account the change in pressure and velocity of the fluid as it passes through the nozzle.
3. Why is the temperature difference important?
The temperature difference in a converging nozzle is important because it affects the efficiency and performance of the nozzle. It can also have an impact on the overall system in which the nozzle is being used.
4. What factors can affect the temperature difference in a converging nozzle?
The temperature difference in a converging nozzle can be affected by factors such as the inlet pressure, the shape and size of the nozzle, and the properties of the fluid passing through it. Changes in any of these factors can alter the temperature difference.
5. How can the temperature difference be controlled?
The temperature difference in a converging nozzle can be controlled by adjusting the inlet pressure, changing the geometry of the nozzle, or using different fluids with varying properties. Additionally, insulating the nozzle can also help to minimize the temperature difference.
