Converging wave interference generating a caustic
In summary, the conversation discusses a paper written by the speaker on converging wave interference generating a caustic. They performed an experiment with a converging lens and observed a change in direction at the caustic, which they found to be a surprising property of nature. They could not find any references to this phenomena and sought help from the physics community. The conversation also touches on the use of Fresnel's equations and optical reversibility in explaining the observed wave nature. The conclusion is that the observed phenomena is a well understood phenomenon and may not require a citation in the paper.
Darrelllashmar
Dear reader, I have written a paper which I require a reference for converging wave interference generating a caustic.
When studying for my degree, I performed Young's double slit experiment with the addiction of a converging lens. I was trying to comprehend Afshar's conclusion/interpretation of the copenhagen agreement. When I placed the converging lens at one focal length from the illuminated double slit, the converging wave interference generated a caustic which beamed an image of the double slit to infinity. Stunned and amazed by this property of nature, I informed my professor. He quickly referred to Fresnel's equations as the explanation and that this was a well understood phenomena. My paper is base on this property of nature yet I can not find any reference to, or any indication that the physics community is currently aware of this phenomena.
Please help.
Thank you for any time and effort spent, Darrell.
Science news on Phys.org
Welcome to PF;
I informed my professor. He quickly referred to Fresnel's equations as the explanation and that this was a well understood phenomena. ... yet I can not find any reference to, or any indication that the physics community is currently aware of this phenomena.
... so you figure that nobody but you and your physics professor know about this? Oh, and Fresnel presumably.
I think what you are referring to is part of the normal formation of caustics.
http://www.pma.caltech.edu/Courses/ph136/yr2012/1207.1.K.pdf
Thanks for your quick reply, however I was referring to the phenomena of converging interfered waves forming an image at the caustic, which then "beams" to infinity. The reference you provide does not cover this phenomena. Please check link provided for a diagram.
http://i.imgur.com/mXAGsrr.png
No, I mean what you have observed is a natural consequence of the established physics.
I'm afraid the diagram doesn't mean much to me. If you put origin of radially diverging light at the focus of the converging lens, wouldn't you expect the light to exit the lens parallel? Perhaps that's not what you meant to draw?
Did you find the same work but ch8.6 for diffraction at the caustic?
Please recall "stunned and amazed" I did expect the light to exit the lens parallel and what's more important is the obvious change of direction at the caustic. The diagram depicts what I observed. I have performed this experiment many times to astonish others. It is as if interfered waves become coherent at the caustic. I have check ch 8/9. there is no mention of a change in direction of the photon at the caustic. There is only construction and destruction of a caustic by ray/photon interpretation, which struggles to explain the beaming to infinity property observed. Optical reversibility still holds though.
However, thank you, I will study ch8.6 as the words "diffraction at the caustic" are used in my paper to describe what I have observed. I expect manipulating the Airy function to model the experiment might show something.
Darrell
Why do you expect a change in direction of the photon at the caustic?
You should remember the wave nature of light.
You have observed bright fringes radiating from the slits to the lens, then converging from the lens to the caustic. Beyond the caustic ... is the image two bright fringes consistent with the slit dimensions?
As you have already pointed out; if a radiant source is placed at one focal length from a converging lens, parallel waves are the result. If this is true, how do these waves interfere? Also, the diverging interference pattern results from diverging waves yet the converging interference pattern is generated by parallel waves. This does not seem consistent with optical reversibility.
However, as far as I can tell, what you are generally saying is that the wave nature I observed is indeed a well understood phenomena and does not require a reference within a paper.
Didn't you have a look at how Fresnel's equations work for this?
Whether you need a citation depends on the role it plays in your writing.
I also suggest taking a look at Fresnel's thousand slit experiment.
FAQ: Converging wave interference generating a caustic
1. What is converging wave interference?
Converging wave interference is a phenomenon that occurs when two or more waves with the same frequency and amplitude meet at a point in space. The resulting interference pattern is a combination of the individual waves, with areas of reinforcement (constructive interference) and cancellation (destructive interference).
2. How does converging wave interference generate a caustic?
A caustic is a bright, concentrated region of light that is formed when converging wave interference occurs. This is because the constructive interference of the waves causes the amplitude of the resulting wave to be higher in this region, resulting in a brighter light. The shape of the caustic is determined by the shape and angle of the waves that are interfering.
3. What are some real-world applications of converging wave interference generating a caustic?
One common application is in the design of optical lenses. By understanding how converging wave interference creates a caustic, engineers can design lenses that focus light in a specific way to create clear images. Caustics are also used in laser technology, holography, and in the study of fluid dynamics.
4. Can caustics be observed in nature?
Yes, caustics can be observed in nature, particularly in bodies of water. When sunlight hits the surface of water, the waves create a caustic pattern on the bottom of the body of water. This can also be seen in other natural phenomena such as rainbows, where the caustic is created by the refraction of light through water droplets.
5. How is converging wave interference different from diverging wave interference?
Converging wave interference occurs when two or more waves meet at a point, while diverging wave interference occurs when waves spread out from a point. In converging wave interference, the waves are traveling towards each other and overlap, resulting in a caustic. In diverging wave interference, the waves are traveling away from each other and do not overlap, resulting in a diffraction pattern.
