Conversation of energy / momentum problem weird circumstance in equations
In summary, the problem involves a projectile of mass M exploding into three fragments, with one traveling in the original direction, one coming to rest, and the third traveling in the opposite direction. The energy released in the explosion is 4.75 times the projectile's initial kinetic energy. The question asks for the velocities of the fragments, which can be found by solving two equations for two unknowns (v1 and v2). After isolating v1, the equations can be combined and reduced to a quadratic equation, which can be solved for v2 in terms of v. The negative solution should be taken for v2, and the values of v1 and v2 should be checked in the initial equations to ensure accuracy
omartech
a projectile of mass M explodes into three fragments while in flight at velocity v. one fragment of mass M/2 travels in the original direction, one of mass 3M/10 comes to rest and the third fragment of mass M/5 travels in the opposite direction. The energy released in the explosion equals to 4.75 times the kinetic energy of the projectile before explosion. What are the velocities of the fragments?
according to my calculations,
Mv (momentum before explosion) = M/2*v1 + M/5*v2 ... since 3M/10 comes to rest. its velocity is zero.
and .. for kinetic energy,
1/2 Mv^2 * 4.75 = 1/2 M/2 *v1^2 + 1/2 M/5 *v2^2.
from these equations we get,
v = v1/2 + v2/5 and 4.75v^2 = v1^2/4 + v2^2/10
Now.. how are these to be solved? in terms of v?
I hope the formation of the above two equations is correct?
Ok but note that when you solve for v2, it must be a negative number then (from the statement of the question)
Two equations for two unknowns, it should be straightforward. For example, isolate v1 from the first equation, plug in the second equation. This will leave you a single equation for the unknown v2. It's a quadratic equation so use the quadratic formula. solve but keep only the negative answer (because that fragment moves to the left). Nwo plug back in the first equation to find v1.
Oh ok i didn't see that coming, but I'm still getting stuck.. i guess 3 years after you leave math u become real rusty in solving stuff ..
so finally, after i isolate v2 i get v1 = v+v2.. i put this in the main equation
to get: 47.5v^2 = 5(v+v2)^2 - 2v2^2...
solving this makes me reach.. 42.5v^2 - 3v2^2 + 10vv2 = 0. Now how do i proceed!
i'm really sorry for not being able to solve such a trivial problem
How did you get this? This does not follow from your equation for conservation of momentum!
Go back to the equation you posted and isolate v1.
yup i got the math wrong initially..
i end up getting two equations.. and when i put the value of v1 in the quadratic equation to reduce it to one variable i get
27.5v^2 + 8*v*v2 - 14/5v2^2 = 0.. I'm sure about this till here..
now I'm confused as to how to solve v2 in terms of v..
how do i treat this quadratic equation.. which is the ax^2 + bx + c = 0.. i don't know which ones are what and how to proceed..
ohh btw .. this is my first ever forum experience and so far its excellent with amazing responses..thanks a lot kdv!
looks good.
The key idea is that you are looking for v2 in terms of v so you must think of v as if it was a number.
So your equation is
[tex] -\frac{14}{5} v_2^2 + 8 v v_2 + 27.5 v^2 =0 [/tex]
The value of "a" is then -14/5. The value of "b" is [itex] 8 v [/itex] and c i s[itex] 27.5 v^2 [/itex]. So you can solve for v2 in terms of v. And as I said before, keep only the negative solution since v2 must be negative.
At the end you should always put back your values of v1 and v2 in your two initial equations to check that you got the correct answers.
By the way, I just reread the question and I am not sure if the starting equation for energy is correct. The question states that the energy released in the explosion is 4.75 times the initial kinetic energy. This is energy produced by the explosion (chemical potential energy transformed into kinetic energy) so, if I read the question correctly, the total kinetic energy at the end is
[tex]1/2 M v^2 + 4.75 times 1/2 M v^2 = 5.75 M v^2/2[/tex]
where the first term is the initial energy and the second term is the energy released in the explosion. I might be wrong but this is the way I interpret the question. But this is the kind of question that could be interpreted in different ways so don't take my word for it.
I am glad it was helpful. You will find this site incredibly useful and interesting!
That's very kind. Thank you.
great!
kdv said:
looks good.
So your equation is
Thanks a lot .. i finally see how to solve these equations.. i was really confused. it was just a long time i hadn't done this.. but yes i'll look into the question clearly to see whether we should add the 4.75 or multiply.. in either case.. we'll get the same kind of equation.. thanks a lot again.. and i'll try and be helpful to others seeking help as well ..
cheers.
cheers.
You are very welcome.
Best wishes
Related to Conversation of energy / momentum problem weird circumstance in equations
1. What is the Law of Conservation of Energy/Momentum?
The Law of Conservation of Energy/Momentum states that energy/momentum cannot be created or destroyed; it can only be transferred or converted from one form to another. This means that the total amount of energy/momentum in a closed system will remain constant over time.
2. How is the Law of Conservation of Energy/Momentum applied in real-life situations?
The Law of Conservation of Energy/Momentum can be applied in various situations, such as collisions, explosions, and pendulum swings. It is also used in the design of machines and devices, such as roller coasters and car brakes, to ensure that energy/momentum is conserved and used efficiently.
3. What are some examples of weird circumstances that can affect the conservation of energy/momentum?
There are several weird circumstances that can affect the conservation of energy/momentum, such as non-elastic collisions, where some energy is lost as heat or sound, and external forces, such as friction or air resistance, which can also impact the transfer of energy/momentum in a system.
4. How are energy and momentum related?
Energy and momentum are closely related concepts. Momentum is a measure of an object's motion, while energy is a measure of its ability to do work. In some cases, energy can be converted into momentum, and vice versa. However, the total amount of energy/momentum in a system will always remain constant due to the Law of Conservation.
5. What happens if the Law of Conservation of Energy/Momentum is violated?
If the Law of Conservation of Energy/Momentum is violated, it means that the total amount of energy/momentum in a closed system is not constant. This can lead to unexpected outcomes and discrepancies in calculations. Scientists continuously test and verify the Law of Conservation in various experiments to ensure its validity.
