Conversion from dry KOH to liquid 45% KOH
In summary, 34 liters of 45% liquid KOH would be required to produce the same result as 42 lbs of 90% purity flakes.
pmason61
Hoping to get my assumptions and math verified here.
We have a process that requires 42 lbs of dry flake KOH (90% purity). Looking to find the equivalent volume (liters) of 45% liquid KOH (11.1 molar strength) - being extracted from a 55 gallon drum.
1 liter of liquid KOH has 11.1 x 56 grams/liter = 621 grams of KOH (1.37 lbs). Adjusting to 90% purity - 1.23 lbs.
So the equivalent volume of liquid KOH required would be 42/1.23 = 34 liters of 45% liquid KOH. Is this correct?
Chemistry news on Phys.org
Do you know that the solution used 90% purity flake KOH? The quoted molarity refers to pure KOH. So this statement is not correct in my opinion: Adjusting to 90% purity - 1.23 lbs.
  • Skeptical
Likes hutchphd
What do you mean, "extracted" from the container drum?
Not "liquid KOH", but "solution of KOH".
As far as I know 45% w/w KOH is 11.7 M, so the numbers seem to be slightly off.
Broadly speaking 34 L of 11.1 M KOH solution should contain the same amount of KOH that is present in 42 lbs of 90% purity flakes. Assuming I guessed correctly what you mean - your answer seems OK.
Likes hutchphd
Some useful information to use would be or include this:
Density for 45% KOH, 1.510 grams per cubic centimeter (Or 1.456 at 25C; depends on temperature)
KOH formula weight is 56.105 grams per mole.
What is the form of measure for the "45%" Potassium Hydroxide? Is this weight per weight, or is this weight per volume? I have seen both in use. You need to know which is yours to be?
For the record: 45% w/v is around 8M.
This gives every indication of being an industrial scale process. Yet neither you nor your colleagues know how to do the calculations?
If that is indeed the case, I suggest you abandon whatever you are attempting until you learn how to work in the necessary environment in a safe manner.
Likes Bystander
