Convert 55lb-65lb Draw Weight to 1/2kx^2
  • Thread starter Thread starter logaliciouz
    Convert Weight
To convert draw weight from pounds to the formula 1/2kx^2, use pounds-of-force directly with feet for x, resulting in energy measured in foot-pounds. For energy in Joules, convert pounds to Newtons using the conversion factor of 4.445 Newtons per pound and use meters for x. The discussion highlights the successful application of an alternative method involving arrow velocity to achieve the desired results. This approach demonstrates the flexibility in calculating energy based on different parameters. Understanding these conversions is essential for accurate energy calculations in archery.
logaliciouz
I'm Canadian, and I'm trying to convert the draw weight (55lb-65lb) into something I can put into 1/2kx^2. Please help!
You can use pounds-of-force directly and using feet for x, so long as you are happy with coefficient k being in pounds/foot, which are standard imperial units for spring coefficient.
Keep in mind that you'll get energy in foot-pounds. If you want to get energy in Joules, you should use meters for x and convert pounds-of-force to Newtons. There are 4.445 Newtons to a pound.
okay thanks, I actually tried using a different method of finding it, using the velocity of the arrow, and it ended up working
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 66 ·
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 16 ·
