Convert atomic mass into Joules
In summary, when 0.0188828901 atomic mass is converted into energy, it creates approximately 2.818116624(34)E-12 Joules. This calculation can be done using the equation E=mc^2, where c is the speed of light (299792458 m/s) and the mass is given in units of atomic mass (1 atomic mass unit = 1.660539040E-27 kg). The accuracy of this calculation is limited by the uncertainty in the value of the atomic mass unit, which is approximately 1.2E-8.
Sebastiaan
84
How much energy is created when 0,0188828901 atomic mass is converted into energy (Joule)
E = m * c^2
speed of light = 299792458
1 atomic mass unit = 1.660539040e-27 kg
1 atomic mass unit = 931,494028 MeV
1 eV = 1,6021766208e-19 Joule
[/B]
mass = 0,01888289012 * 1,660539040e-27 = 3,13557762322902848e-29
Applying this to E= mc^2 I get
3,13557762322902848e-29 * 299792458 * 299792458= 2,818116627e-12 joules
Another method is that I first convert mass to MeV and then to Joules I get
0,01888289012 * 931,494028 * 10e6 * 1,6021766208e-19 = 2,8181164240e-12 joules
However when I attempt to atomic mass to Joule using a online converter
(which uses 1 unified atomic mass unit = 1.49241795273396E-10 joule ) I get
0,01888289012 * 1,49241795273396e-10 = 2,818116421e-12 joules
As you can see I get different outcomes depending on the used method.
Which one of the result would be most accurate?
From your link:
The unified atomic mass unit u or dalton Da is the standard unit that is used for indicating mass on an atomic or molecular scale. It is defined as one twelfth of the mass of a carbon-12 atom or 1.6605•10⁻²⁷ kg. During a nuclear reaction the mass of its products is less than the mass of the initial substance. This is so because the mass is converted into energy. The energy liberated in the nuclear reaction is given by Einstein's equation E=mc² where E is the energy, m is the mass and c = 299 792 458 m/s is the speed of light. Therefore, (1 J)/c² = 6.700 535 85(30)•10⁹ u
I see 8 digits in 1J/c2, so 1.49241795273396 10-10 suggests too many digits.
For fundamental constants, consult the http://pdg.lbl.gov/2017/reviews/rpp2016-rev-phys-constants.pdf results
If I'm not mistaken, It does not appear to list atomic mass to Joule.
##c## is exact
Yes but the 1 eV = 1.672621898e-27 kg is only 10 digits from which the last 2 digits are uncertain with a mean deviation of 0.0000000021 so only 7 digits are truly accurate
I get 2.818116624(34)E-12 J
Don't take the proton mass; take the amu !
I'm confused, how exactly did you calculate this?
0.0188828901000 * 1.66053904E-27 * 299792458^2 = 2.81811662422E-12 in excel (works in double precision, so some 15 digits; good enough here)
http://pdg.lbl.gov/2017/reviews/rpp2016-rev-phys-constants.pdf in 1.660539040E-27 is 2E-35, so relative unertainty 1.2E-8
Result times relative uncertainty gives 3.4E-20 hence reported as 2.818116624(34)E-12 J
Likes Sebastiaan
Related to Convert atomic mass into Joules
1. How do I convert atomic mass into Joules?
To convert atomic mass into Joules, you can use the formula E = mc^2, where E is the energy in Joules, m is the atomic mass in kilograms, and c is the speed of light in meters per second (approximately 3 x 10^8 m/s).
2. Why do we need to convert atomic mass into Joules?
Converting atomic mass into Joules allows us to understand the amount of energy contained in a specific amount of matter. This is important in many fields of science, including nuclear physics and chemistry.
3. Can atomic mass be directly converted into Joules?
No, atomic mass cannot be directly converted into Joules. It must be multiplied by the speed of light squared (c^2) to obtain the energy in Joules.
4. What is the significance of converting atomic mass into Joules?
The conversion of atomic mass into Joules helps us understand the relationship between mass and energy, as described by Einstein's famous equation E = mc^2. It also allows us to make calculations and predictions in various scientific fields.
5. Is there a specific unit for atomic mass in Joules?
No, there is no specific unit for atomic mass in Joules. Joules is a unit of energy, while atomic mass is typically measured in atomic mass units (amu) or kilograms (kg). However, when converting atomic mass into Joules, the unit used for mass must be consistent with the unit used for the speed of light (m/s).
