Convert Longitude/Latitude dependent upon the location on the Earth
In summary, the distance between each degree of longitude varies proportionally to the cosine of the latitude. This means that the distance between two longitude lines is smaller at the poles and larger at the equator. While a simple conversion of the east-west distances will give a linear relationship as you move north and south, taking into account the cosine of the latitude will give a more accurate representation of the distance between longitude lines. This is important to consider when planning to plot observations made by a satellite in two grid boxes, one located at the equator and one at the mid latitudes.
Tone L
73
I am planning to plot all the observations made by a satellite in two respective grid boxes. One grid located at the equator and one grid located at the mid latitudes...
Each grid box will be a 10° x 10° box. However, due to the shape of the Earth the area of each box will indeed not be the same size. Is there some formula to convert latitudinal and longitundal degrees dependent on location of earth? To some useful unit (km).
Thanks!
The north-south distances will be one to one everywhere. A simple conversion of the east-west distances will be proportional to the latitude.
For example, at the equator, 10 degrees in the east-west direction is 25,000 miles / 36 = 694 miles. This distance is essentially zero at the pole, so that it's a linear relationship as you move north and south. Therefore at 80 degrees north, 10 degrees of longitude would be a ninth of 694 or about 77 miles.
Note that these are simple approximations and do not take into account things like datums, etc.
Hi Borg:
I am pretty certain that the longitude linear distance for 10 degrees is the same as the 10 degree distance at the equator times the cosine of the latitude. This is based on a spherical Earth. Some small and a bit complicated corrections would be needed for the Earth's approximately ellipsoidal shape. Smaller and even more complicated corrections are required if you want to take the actual shape of the Earth into consideration.
The longitudinal distance at the poles is zero. That is the grid "boxes" between 80 degrees and 90 degrees will be triangles.Regards,
Buzz
@Buzz Bloom I think that we're saying generally the same thing. The distance between two latitudes along a longitudinal line is the same for every degree of distance. It's the distance between two longitudinal lines that changes depending on the latitude.
Hmm. @Borg I do not see it quite your way.
As you know - The Earth is not a perfect sphere. So, Geodesy has a little complexity.
Each degree of latitude is approximately 69 miles (111 kilometers) apart. The range varies (due to the Earth's slightly ellipsoid shape) from 68.703 miles (110.567 km) at the equator to 69.407 (111.699 km) at the poles. This is convenient because each minute (1/60th of a degree) is approximately one [nautical] mile.
Parallel distances across longitude A to longitude B is more interesting.
@Anthony LaRosa
What exactly do you need? How much accuracy? The usual choice is probably a great circle distance between two points given a lat long for each one.
See Vincenty formula for special case of ellipsoids:
https://en.wikipedia.org/wiki/Vincenty's_formulae
You can often use haversines because if the N/S differences are small a spherical approximation is probably okay:
https://en.wikipedia.org/wiki/Haversine_formula
It gets more interesting if you are doing some kind of surveying, where accuracy needs to greater than locating the nearest McDonalds restuarant.
You get to decide.
Likes Tone L
I must be wording things in a way that is confusing. Yes, I agree that the distance between each degree of latitude is mostly the same (ignoring the spheroid issue). Stated your way, I've been trying to say that the distance between each degree of longitude varies proportionally to the latitude.
Likes Tone L
This is the real question. Most of this depends on how accurate the OP wants to be. A simple conversion gets your nuke on the right block. Taking the rest into account let's you pick whose window you want to put it through. :oldtongue:
@Borg. You keep saying that it is proportional to the latitude. This is not true. As BuzzBloom said, the distance between two longitude lines depends on the cosine of the latitude. So, while 10 degrees of longitude is 694 miles at the equator, at 80 degrees latitude it is 694 * cos(80) = 120 miles, not the 77 miles you quoted. At 10 degrees latitude, your linear approximation would say 10 degrees of longitude is 694 * 8/9 = 617 miles, while the correct answer is at 10 degrees latitude, 10 degrees of longitude = 694 * cos(10) = 683 miles. These differences are large, and will not get you "on the right block".
Likes Tone L, jim mcnamara and Borg
Thanks for clarifying my mistake. It has been a long time since I've had to do those calculations.
Ugh. What was I thinking yesterday? :oldruck:
Find out about WGS84 here; https://en.wikipedia.org/wiki/World_Geodetic_System#WGS84
This code converts latitude, longitude and height to x, y, z coordinates in metres.
You can then map that to your grid box.
Code:
Sub wgs84(_
Byval latit As Double,_
Byval lng As Double,_
Byval h As Double,_
Byref x As Double,_
Byref y As Double,_
Byref z As Double )
Const a As Double = 6378137 ' Defined semi-major axis, metres
Const ba As Double = .9933056200098587 ' square of b to a ratio bb/aa
Const ee As Double = 6.694379990141316D-03 'square of first eccentricity f(2-f)
Dim As Double sinlat = Sin(latit)
Dim As Double RofC = a / Sqr(1 - ee * sinlat * sinlat) ' radius of curvature
Dim As Double term = (RofC + h) * Cos(latit)
x = term * Cos(lng) ' x-axis is Atlantic Ocean positive
y = term * Sin(lng) ' y-axis is Indian Ocean positive
z = (h + (RofC * ba)) * sinlat ' z-axis is North Pole positive
End Sub
Related to Convert Longitude/Latitude dependent upon the location on the Earth
1. How do you convert longitude and latitude coordinates?
The conversion of longitude and latitude coordinates is done by using mathematical formulas that take into account the shape of the Earth and its rotation. The most commonly used formula is the Haversine formula, which calculates the distance between two points on a sphere.
2. What is the difference between longitude and latitude?
Longitude and latitude are two different ways of measuring locations on the Earth's surface. Longitude measures the distance east or west of the Prime Meridian, while latitude measures the distance north or south of the Equator.
3. How do you convert longitude and latitude to degrees, minutes, and seconds?
To convert longitude and latitude to degrees, minutes, and seconds, you can use the following formulas:
Degrees = integer part of the coordinate
Minutes = (decimal part of coordinate * 60)
Seconds = (decimal part of minutes * 60)
4. What is the purpose of converting longitude and latitude coordinates?
Converting longitude and latitude coordinates allows us to accurately determine the location of a point on the Earth's surface. This is important for navigation, mapping, and various scientific studies that require precise location data.
5. Can you convert longitude and latitude coordinates to different coordinate systems?
Yes, longitude and latitude coordinates can be converted to different coordinate systems such as Universal Transverse Mercator (UTM) or Military Grid Reference System (MGRS). This is useful for specific applications that require a different way of representing location data.
