Convert mg/s to SCCM (Standard Cubic Centimeters per Minute)
In summary, the conversation discusses the procedure for converting mass flow in mg/s to volumetric flow in standard cubic centimeters per minute (SCCM) using the ideal gas law equation of state. The key is to use the proper standard conditions for the gas, which is Ps = 101325 Pa, Ts = 273.15 K, and Zs = 1. The conversion factors for mass flow to molar flow and molar flow to SCCM are also provided.
jagadeeshr
Hello,
Can anyone explain the procedure to convert mg/s to SCCM?
I'm working with an Alicat Mass Flow Controller, which regulates Argon (Ar) mass flow from 1 to 6 mg/s at 27o C or 300 K (room temperature).
For documentation purpose, I need mass flow in terms of mg/s, as well as, SCCM.
Thank you
Jagadeesh
Chemistry news on Phys.org
Hi,
mg/s is a mass flow and SSCM is a volume flow.
They are linked via the equation of state. For argon you can use the ideal gas law ##pV = nRT##
Key is to find the proper standard conditions (confusion lurks, so be sure to mention them)
Hi,
BvU is correct. To derive the relationship of cubic centimeters to 'standard' cubic centimeters of gas, you use the gas law equation of state. Standard means Ps= 101325 Pa, Ts = 273.15 K and Zs = 1.
The derivation from reference [1] below should be sufficient to explain. It is a matter of setting the number of moles equivalent.
nx =ns => Px * Vx / (Zx*Tx) = Ps * Vs / Ts
Then solve for Vs = standard volume of gas
To answer your question more directly, use these conversion factors.
Molar flow is converted to standard volumetric flow via the standard molar volume 22.414 x 10-3 m3 mol-1 [2].
1 sccm = 0.74358 µmol/s [3].
To convert from mass flow (mdot) to molar flow (ndot):
ndot = mdot / MolarMass
To convert between molar flow rate and
sccm = (Standard Molar Volume) * (unit conversion factor) * ndot = 22.414 * 60e3 * ndot
In this case, the unit conversion factor is for seconds to minutes and m3 to cm3
References:
[1] Converting mass flow to volumetric flow rate. https://www.first-sensor.com/cms/upload/appnotes/AN_Massflow_E_11153.pdf
[2] Codata standard molar volume. https://physics.nist.gov/cgi-bin/cuu/Value?mvolstd|search_for=molar+volume
[3] NIST published conversion value from sccm to mol/s. https://tsapps.nist.gov/publication...4154&msclkid=d34cae6cabff11ec8093320a4d23498a
Likes chemisttree, jim mcnamara, berkeman and 1 other person
FAQ: Convert mg/s to SCCM (Standard Cubic Centimeters per Minute)
How do I convert mg/s to SCCM?
To convert milligrams per second (mg/s) to standard cubic centimeters per minute (SCCM), you will need to use a conversion factor. The conversion factor for this specific conversion is 16.7. Simply multiply the value in mg/s by 16.7 to get the equivalent value in SCCM.
Why do we need to convert mg/s to SCCM?
Milligrams per second is a unit of mass flow rate, while SCCM is a unit of volumetric flow rate. In scientific experiments, it is often necessary to convert between these two units depending on the type of measurement being taken. For example, in gas flow measurements, SCCM is a more commonly used unit.
Can I use an online converter to convert mg/s to SCCM?
Yes, there are many online converters available that can easily convert between different units of measurement, including mg/s and SCCM. However, it is always important to double-check the results to ensure accuracy.
Is there a formula for converting mg/s to SCCM?
Yes, the formula for converting mg/s to SCCM is: SCCM = mg/s * 16.7. This formula can also be rearranged to convert from SCCM to mg/s by dividing by 16.7.
Are there any other units that can be used to measure flow rate besides mg/s and SCCM?
Yes, there are many other units that can be used to measure flow rate, such as kilograms per second, pounds per hour, and liters per minute. The choice of unit depends on the specific application and the type of substance being measured.
