MHB Convert r=7cos(theta) into a rectangular equation
The polar equation r = 7cos(θ) can be converted into a rectangular equation by using the relationships between polar and rectangular coordinates. Starting with r = 6(cos(θ)), we substitute cos(θ) with x/r, leading to the equation r^2 = 6x. By substituting r^2 with x^2 + y^2, we arrive at x^2 + y^2 = 6x. Rearranging this into standard form, we complete the square to find that the equation represents a circle with a radius of 3 units, centered at the point (3, 0). This conversion illustrates the relationship between polar coordinates and their rectangular counterparts effectively.
Elissa89
So we're learning to plot polar equations, which easy enough. But I got a question in the homework that wasn't covered in class:
Convert r=7cos(theta) into a rectangular equation. Use x and y values. I know how to convert when it's x=r*cos(theta) or y=r*sin(theta) and r and theta is given. But this is different and I don't know how to do it.
Mathematics news on Phys.org
Okay, we are given the polar equation:
$$r=6\cos(\theta)$$
Now, from:
$$x=r\cos(\theta)\implies \cos(\theta)=\frac{x}{r}$$
We may write:
$$r=6\left(\frac{x}{r}\right)$$
Multiply through by \(r\):
$$r^2=6x$$
We know:
$$r^2=x^2+y^2$$
Hence, we have:
$$x^2+y^2=6x$$
This would technically suffice, but I would prefer to continue and put into standard form:
$$x^2-6x+y^2=0$$
Complete the square on \(x\):
$$(x-6x+9)+y^2=9$$
$$(x-3)^2+y^2=3^2$$
Now it's easy to see we have a circle of radius 3 units centered at (3,0).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
