Convert to "Of Date" Apparent coordinates from "J2000" coordinates
In summary, "Of Date" Apparent coordinates can be converted to "J2000" coordinates by taking into account the effects of precession, nutation, and aberration. These effects must be corrected for in order to accurately convert the coordinates. The process involves using trigonometric functions and formulas to adjust for the changes in Earth's position and orientation over time. Once converted, the "J2000" coordinates will reflect the position of an object relative to the Earth's center of mass at the start of the year 2000. This conversion is important in astronomy and navigation, as it allows for the comparison of celestial objects observed at different times and from different locations.
Philosophaie
462
How do you convert to "Of Date" or "Apparent" coordinates from "J2000" coordinates?
The website:
http://ssd.jpl.nasa.gov/horizons.cgi#results
there are two options for displaying RA and DEC: Astrometric and Apparent. Astrometric is the J2000 coordinates and Apparent is the "Of Date".
http://www.ephemeris.com/goto.php
Just lists the Apparent
www.stellarium.org software
Lists both "Of Date" and J2000 coordinates.
My question is: Is there a formula to convert between the two coordinate systems?
Short answer - what are you trying to do? Can you write programs in some language like maybe C or FORTRAN?
I suppose you can use a sophisticated programmable TI calculator...
@D H probably can help with a lot more detail - the JPL has software that does astronomical calculations. And copes with Jxxxx. AFAIK.
Jan Meeus has several books meant for amateur astronomers. Please consider one of them as a great starting point.
Exmple: https://www.amazon.com/dp/0943396352/?tag=pfamazon01-20
As an aside - are you trying to project orbits of Solar System objects into the future? All of what I did was always okay with existing ephemera.
Likes Philosophaie
Related to Convert to "Of Date" Apparent coordinates from "J2000" coordinates
What is the purpose of converting from "J2000" coordinates to "Of Date" Apparent coordinates?
The purpose of converting from "J2000" coordinates to "Of Date" Apparent coordinates is to account for the slight variations in the Earth's rotation and orbit over time. "J2000" coordinates are fixed to a specific date (January 1, 2000) and do not take into account these variations, while "Of Date" Apparent coordinates are adjusted to the specific date and time of observation.
What are "J2000" coordinates and "Of Date" Apparent coordinates?
"J2000" coordinates refer to a coordinate system fixed to the Earth's mean position on January 1, 2000 at noon (or Julian Date JD 2451545.0). "Of Date" Apparent coordinates refer to a coordinate system that takes into account the Earth's rotation and orbit at the specific date and time of observation.
What is the process for converting from "J2000" coordinates to "Of Date" Apparent coordinates?
The process for converting from "J2000" coordinates to "Of Date" Apparent coordinates involves using mathematical equations and algorithms to adjust for the Earth's rotations and orbital movements. This includes calculating the Earth's precession, nutation, and aberration.
What tools or software can be used to convert coordinates?
There are various tools and software that can be used to convert coordinates, such as astronomical calculators, planetarium software, and astronomy apps. Some popular tools include Stellarium, SkySafari, and Celestia.
How accurate are "Of Date" Apparent coordinates compared to "J2000" coordinates?
"Of Date" Apparent coordinates are more accurate than "J2000" coordinates because they take into account the Earth's movements at the specific date and time of observation. However, the accuracy can vary depending on the precision of the calculations and the accuracy of the input data.
  • Astronomy and Astrophysics
