mitchellch
- 7
As a newbie, I've completed my first reasonably sophisticated design and have a working board...sort of. The power supply I designed 'bricks' the board (although my power LED glows brightly :) ). If I hand-wire in a known good +5v/GND source (isolating my on-board power supply) the rest of my board works perfectly.
I need to drive the Atmega328 CPU based (originally Arduino) logic off +5v derived originally from a 24vac input source. Here is the simple schematic (including part numbers, values, etc.) for the power portion of my schematic (data sheet links below).
Actual voltage readings off my board are as follows...
+24v: +24.31v
+9v: +7.86v
+5v: +4.30v
The low +9v and +5v values confuse me. The data sheets (links below) often show "compensation capacitors", which I excluded out of ignorance (and the fact that they are referred to as "optional" in the MC7805CT data sheet).
Any suggestions? I am so close to getting the project working, any help would be greatly appreciated.
TIA,
Mitch
Here are links to the datasheets for the three significant parts.
DF01M Bridge Rectifier
LM7809ACT 9v Regulator
MC7805CT 5v Regulator
+24v: +24.31v
+9v: +7.86v
+5v: +4.30v
TIA,
Mitch
