paulmdrdo1
- 385
0.17777777777 convert into a ratio.
M R said:Hi,
This is [tex]0.1 + 0.077777=\frac{1}{10}+\frac{7}{100}+\frac{7}{1000}+...[/tex] where you have a GP to sum.
Or [tex] \text{Let } x=0.0777..[/tex] so that [tex]10x=0.777..[/tex].
Subtracting gives [tex]9x=0.7[/tex] and so [tex]x=\frac{7}{90}[/tex]. Now just add [tex]\frac{1}{10}+\frac{7}{90}[/tex] and simplify.
I should also say that we can write a decimal as a fraction but we can't write it as a ratio.
paulmdrdo said:what do you mean by "GP"?
[tex]\text{Convert }\,0.1777\text{...}\,\text{ to a fraction.}[/tex]
M R said:Since two digits repeat, a difference of two in the powers of ten that you use leave no decimal part when you subtract.
If you use 1000 and 10 you will get
1000x=3547.474747...
10x=35.474747...
So 990x=3512 and x=3512/990=1756/495.
I'm adopting Soroban's approach as I prefer it to what I did earlier.
paulmdrdo said:"a difference of two in the powers of ten" -- what do you me by this? sorry, english is not my mother tongue. bear with me.
paulmdrdo said:how would I decide what appropriate power of ten should i use?
for example i have 3.5474747474... how would you convert this one?
To convert a repeating decimal to a ratio of integers, you need to follow these steps:
No, not all repeating decimals can be converted to a ratio of integers. Only repeating decimals with a finite number of digits in the repeating pattern can be converted to a ratio of integers. If a repeating decimal has an infinite repeating pattern, it cannot be converted to a ratio of integers.
Converting a repeating decimal to a ratio of integers can help us to represent the decimal in a simpler and more understandable form. It can also allow us to perform calculations with the number more easily.
To check if the conversion is correct, you can use a calculator to divide the numerator by the denominator of the ratio. The result should be equal to the original repeating decimal.
Yes, there is a shortcut method called the "bar notation" method. In this method, the repeating pattern in the decimal is represented by a bar placed over the digits. The number of digits under the bar corresponds to the number of digits in the repeating pattern. Then, the ratio can be written by placing the digits under the bar as the numerator and the number of 9s equal to the number of digits in the repeating pattern as the denominator.
