Converting degree into 'x' (integration)
In summary, the conversation discussed integrating x²/(sqrt1-x²) using the triangle method and substituting sin(t) for x. The resulting answer was 1/2t-1/2sin(2t)+c, but the need for the answer to be in x format led to confusion. It was eventually determined that the integral of 1/2sin(2t) is actually 1/4sin(2t) due to a missing factor of 2. This led to the correct answer of 1/2x*sqrt(1-x²).
L²Cc
149
After integrating x²/(sqrt1-x²) using the triangle method and thereby substituting sin¤ for x, I ended up with the result 1/2¤-1/2sin2¤+c. For my answer toge complete, I must have the ¤ in x format. I managed to convert the 1/2¤, which is simply 1/2arcsinx but I couldn't for 1/2sin2¤, my answer did not agree with the textbook's which read 1/2x(sqrt1-x²)...
My computer won't read latex at the moment so please excuse the amateur notation. Thank you.
I think I covered it all above!
If I call your substitution sin(t) (I don't know what symbol you were trying to put in), sin(2t)=2*cos(t)*sin(t). Put t=arcsin(x) in there.
Oh I see, you used the trig identity...and then I refer back to the triangle to figure out what's cos(t)...Thank you!
Following your reasoning, 1/2*sin(2t) becomes 2x*sqrt(1-x²). The two cancels out when I plug it back into 1/2*sin(2t), and this can't be since the answer is 1/2*x*sqrt(1-x²)??!
I get that the integral of sin(t)^2 is t/2-sin(2t)/4. You are missing a factor of 2.
So you're suggesting that the integral of 1/2cos(2t) is 1/2sin(2t) ?! (can you please elaborate as to how you came up with the answer?)
No, I'm suggesting it's sin(2t)/4. Substitute u=2t, du=2dt. That's your missing 2.
hmm I see, I never did that before, I simply went on with the integrating whenever it was 1/2-1/2cos2t for example...and I always obtained the right answer, weird! But thank you!
FAQ: Converting degree into 'x' (integration)
How do you convert degrees to radians?
To convert degrees to radians, you can use the formula: radians = (degrees * π) / 180. This formula involves multiplying the degree value by pi (approximately 3.14159) and then dividing by 180.
What is the difference between converting degrees to radians and integrating with respect to x?
Converting degrees to radians is a simple mathematical conversion, whereas integrating with respect to x is a calculus operation. Converting degrees to radians results in a new unit of measurement, whereas integrating with respect to x involves finding the area under a curve.
What is the purpose of converting degrees to radians in integration?
Converting degrees to radians is necessary for integration because most mathematical functions and equations are written in radians. By converting degrees to radians, you can better manipulate and solve these equations using calculus and integration techniques.
Can you integrate with respect to a variable other than x?
Yes, you can integrate with respect to other variables besides x. The variable you integrate with respect to is known as the "variable of integration." This is typically denoted with a lowercase letter, such as t or y.
How do you convert from radians to degrees?
To convert from radians to degrees, you can use the formula: degrees = (radians * 180) / π. This formula involves multiplying the radian value by 180 and then dividing by pi (approximately 3.14159).
