Converting energy to force at impact
In summary, the conversation discusses a test to determine the average force required to damage a section of steel pipe using an impact tester. There is uncertainty about how to convert energy to force and which distance to use, as using the crumple distance may not accurately reflect the material being tested. The correct formula to determine force from energy is f=E/d, which means a longer crumple distance results in a smaller force for the same energy.
BPLafser
Hello
This should be simple but for some reason I'm having some trouble with a test we are performing.
The end goal is to determine the average force required to damage a section of steel pipe experimentally with an impact tester. We built the tester and know what energy will hit the side of the tube (2" diameter, 1/8" wall thickness grade 50 steel) but I am uncertain how to correctly turn this to a force. I know that J/m can be converted to force but there is some debate on which distance we should be using.
It would make logical sense for us to use the distance the tube crumpled by upon impact but I am unsure as to how this would work as it does not consider the material we are testing. We could use a cardboard tube and get a much higher force than steel for the same height.
And advice you could offer would be greatly appreciated.
BPLafser said:
Hello
No. energy is force times distance(E=fd). So to get force from energy you would use f=E/d. A longer crumple distance gives as smaller force for the same energy.
Likes BPLafser
Thank you.
Related to Converting energy to force at impact
1. How is energy converted into force at impact?
When an object with energy, such as a moving car or a falling object, collides with another object, some of its energy is transferred to the other object in the form of force. This transfer of energy is known as impact force.
2. What factors affect the conversion of energy to force at impact?
The amount of energy transferred into force at impact depends on the mass, speed, and direction of the moving object, as well as the stiffness and surface area of the objects involved in the collision.
3. How is the impact force calculated?
The impact force can be calculated by multiplying the mass of the moving object by its velocity at impact. This is known as the momentum equation: force = mass x velocity.
4. Can energy be converted into force without impact?
Yes, energy can be converted into force without impact through other means such as friction, compression, or tension. For example, when a person lifts a heavy object, the energy they use is converted into force to overcome the weight of the object.
5. How can the conversion of energy to force at impact be applied in real life?
The conversion of energy to force at impact is a fundamental concept in engineering and physics. It is used to design and test various structures, such as car bumpers and safety barriers, to withstand impact forces and protect the occupants. It also plays a crucial role in sports equipment, such as helmets and padding, to reduce the impact force on the body during collisions.
  • Mechanical Engineering
