Converting Force Measurement to Pressure
The discussion focuses on converting force measurement to pressure using a zip-tie structure that compresses an elastic part. The user seeks to create a simple calibrator to correlate measured force (in Newtons) to pressure (in Pascals), with a pressure range expected between 6 kPa and 33 kPa. A proposed solution involves using a flexible silicone tube filled with water, where the hydrostatic pressure is determined by the height difference in the tube. The tube's collapse under the zip-tie will occur over a narrow pressure range, facilitating the calibration process. The conversation also touches on the relationship between tension and pressure in a belt system wrapped around a cylinder.
Oseania
TL;DR Summary
A zip-tie like structure squeezes an elastic part. I can measure a force that is related to the squeezing pressure. I need to create a calibrator that would allow me to correlate the force to the squeezing pressure.
I have a zip-tie like structure, which when pulled, squeezes an elastic part. Think of it like a having a zip-tie around your finger.
I can measure a force that is related to the squeezing pressure. This relationship between force and pressure is quite linear. I would now need to create a calibrator that would enable me to correlate between the measured force (N) to the pressure (Pa) that is imposed to the elastic part. The diameter of the zip-tie is about 22mm and it squeezes to about 17mm diameter.
Now, I first started to think that I would have some inflatable balloon with fixed pressure. The zip tie wouldn't move when the pressures match. I would prefer to keep this calibrator relatively simple at first stage, so any crazy, easily built ideas are welcome ;-).
Thanks.
A flexible silicone tube, sealed at the bottom, filled with water from a reservoir with a large exposed water surface area above. The height difference sets the hydrostatic pressure at the bottom of the tube.
Bundle the bottom end of the tube in with the elastic material, tighten the zip-tie until the tube is half-collapsed under the tie. The tube collapse will occur over a narrow pressure range.
What range of pressure are you expecting ?
Suppose you have a belt under tension T wrapped around a rigid cylinder of radius R. Let P be the normal force per unit area exerted by the cylinder on the belt. A force balance on the region of the belt between angular locations ##\theta## and ##\theta + d\theta## gives $$PRd\theta w=Td\theta$$where w is the width of the belt. from this it follows that $$P=\frac{T}{Rw}$$
Thanks,
the pressure range is from 6 kPa to about 33kPa.
Thanks, just to verify that w is the width?
That's what I said.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
