Converting from sin to cos appropriately with phasors
  • Thread starter Thread starter wellmoisturizedfrog
    Cos Phasors Sin
The discussion centers on the confusion regarding the appropriate use of phase shifts when converting between sine and cosine functions in phasor analysis. It highlights that adding pi/2 to a sine function results in a cosine function, while subtracting pi/2 leads to a negative cosine function, effectively inverting the signal. The original poster seeks clarification on when to use each phase shift, as their professor suggests there are specific contexts for each. The conversation emphasizes the importance of understanding the phase relationship in the complex domain and encourages providing detailed problems for better assistance. Overall, clarity on phase shifts is crucial for accurate phasor representation in transmission line problems.
wellmoisturizedfrog
TL;DR Summary
Difficulty understanding when to add pi/2 vs when to subtract pi/2.
My transmissions line class often features problems where the voltage is expressed as a sin, not a cos. Obviously a phase shift of pi/2 is sufficient to convert between the two. However, I have trouble understanding when adding pi/2 is appropriate as opposed to subtracting pi/2. As per my understanding, both should be sufficient to achieve the desired conversion, but my professor says otherwise. While I understand that the angle should reflect the position of the phasor in the complex domain, I still feel as though I am missing something. Could anyone offer a concrete clarification of this matter?
Can you be more specific? Note that:
$$\sin(x +\frac{\pi}2) = \cos(x)$$
Likes sophiecentaur
You might get better help if you post an actual problem, with full details, and ask that question. For any homework-type problem, you need to show as much of your own work as possible. There is a specific format for homework-type problems.
##sin(\Theta - \frac{\pi}{2}) = -cos(\Theta)##
##sin(\Theta + \frac{\pi}{2}) = cos(\Theta)##
etc.
Can you explain a bit more about what you are unsure of?
TL;DR Summary: Difficulty understanding when to add pi/2 vs when to subtract pi/2.
One will convert sin() to cos(), the other will do the same, but will invert the signal, by the net phase shift of pi.
I wonder if he really said that or if you mis- interpreted him (i.e. just in one particular example). The 'timing of events (phases) can sometimes be very relevant but not always.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
