Converting "Luminosity per unit wavelength" to "Luminosity per unit frequency"
In summary, the conversion from luminosity per unit wavelength (L_λ) to luminosity per unit frequency (L_ν) is given by L_ν = L_λ (λ^2/c). If the shape of a spectrum is proportional to a power-law (L_λ = λ^(β)), then an analytical expression for L_ν in terms of β can be found by substituting in the conversion equation, resulting in L_ν ~ ν^(β-2). This can be used to compare how spectral shape changes based on the definition of the spectrum.
Lizard
If there is a luminosity per unit wavelength defined as L_λ dλ, am I correct in thinking that the conversion to luminosity per unit frequency (L_ν) would be L_ν = L_λ (λ^2/c)?
And building off of that, if the shape of a spectrum was proportional to a power-law: L_λ = λ^(β), is there a way to find an analytical expression for L_ν in terms of β? From plugging the above in, would it be accurate to say that L_ν = ν^(β-2)?
Note: this isn't for homework or anything--I'm just looking for an easy way to compare how spectral shape would change based on the way the spectrum is defined.
Astronomy news on Phys.org
That would be Lν ~ ν-(β+2)
Likes hutchphd
Related to Converting "Luminosity per unit wavelength" to "Luminosity per unit frequency"
1. How do you convert luminosity per unit wavelength to luminosity per unit frequency?
To convert luminosity per unit wavelength to luminosity per unit frequency, you can use the formula: Luminosity per unit frequency = Luminosity per unit wavelength x (wavelength)^2 / (speed of light)^2. This formula takes into account the relationship between wavelength and frequency, as well as the speed of light.
2. Why is it important to convert luminosity per unit wavelength to luminosity per unit frequency?
Converting luminosity per unit wavelength to luminosity per unit frequency allows for a more accurate measurement of the light emitted by an object. This is because different objects emit light at different wavelengths, but the frequency remains constant. Converting to luminosity per unit frequency allows for a more direct comparison between objects.
3. Can you provide an example of converting luminosity per unit wavelength to luminosity per unit frequency?
For example, if an object has a luminosity per unit wavelength of 10 watts/meter, and the wavelength is 500 nanometers, the luminosity per unit frequency would be calculated as: 10 watts/meter x (500 x 10^-9 meters)^2 / (3 x 10^8 meters/second)^2 = 10 watts/meter x 2.78 x 10^-17 = 2.78 x 10^-16 watts/Hz.
4. What is the difference between luminosity per unit wavelength and luminosity per unit frequency?
Luminosity per unit wavelength is a measurement of the amount of light emitted at a specific wavelength, while luminosity per unit frequency is a measurement of the amount of light emitted at a specific frequency. Wavelength and frequency are inversely related, meaning that as one increases, the other decreases. Converting between the two allows for a more comprehensive understanding of the light emitted by an object.
5. Is there a specific unit for luminosity per unit frequency?
Yes, the unit for luminosity per unit frequency is watts/Hz (watts per Hertz). This unit represents the amount of energy emitted per second at a specific frequency. It is commonly used in astronomy and physics to measure the luminosity of objects such as stars and galaxies.
  • Astronomy and Astrophysics
  • Quantum Physics
  • Thermodynamics
  • Other Physics Topics
