Converting Octal 421 to Nibble, Byte, Word & Long Word
  • MHB
  • Thread starter bergausstein
In summary, we discussed converting an octal number to nibble, byte, word, and long word. We determined that each octal digit requires 3 bits, which means a 3-digit octal number will require 9 bits. This also means that we will need 3 nibbles to store a 3-digit octal number. Additionally, we found that 1 byte is equal to 2 nibbles, 1 word is equal to 2 bytes, and 1 long word is equal to 2 words. Finally, we confirmed that your answers for the conversion of the octal number to different data types are correct.
bergausstein
191
We are asked to convert the octal number 421(base 8) to nibble, byte, word and long word. Please help me how to go about it. I know that a nibble is half-byte wihich has 4 bits in it. But to cconvert an octal number to nibble is something I don't know how to do please help me. Thanks.
Technology news on Phys.org
How many bits does it take to store each digit of an octal number?
Hi markfl! digits in octal take 3 bits.
Correct, since each octal digit can take one of 8 values (0-7) and $8=2^3$. So, a 3 digit octal number will require 9 bits, which means how many nibbles will be required?
It will take 2 nibbles a 1 bit?
So, 4 = 100, 2 = 010 , 1 = 001. In binary, 100010001.
In nibbles, 1 0001 0001. Is this correct?
I am assuming we cannot have "partial nibbles" so we would need \(\displaystyle \left\lceil\frac{9}{4}\right\rceil=3\) nibbles:
0001 0001 0001
How about the other data types?
0001 0001 0001
In bytes 00000001 00010001
In word 0000000100010001
In long word 00000000000000000000000100010001
Are my answers correct?
Yes, I agree with your answers. (Yes)
FAQ: Converting Octal 421 to Nibble, Byte, Word & Long Word
How do you convert Octal 421 to Nibble?
To convert Octal 421 to Nibble, you will need to break the octal number into individual digits. In this case, you would have 4, 2, and 1. Then, you will need to convert each digit into its binary equivalent. Finally, you can combine the binary digits into groups of 4, which will give you the Nibble representation of Octal 421.
What is the Byte representation of Octal 421?
To find the Byte representation of Octal 421, you will need to follow the same steps as converting to Nibble. However, instead of grouping the binary digits into groups of 4, you will group them into groups of 8. This will give you the Byte representation of Octal 421.
How can I convert Octal 421 to Word?
The conversion to Word is similar to converting to Nibble and Byte. First, you will need to convert each digit of the octal number into its binary equivalent. Then, you will group the binary digits into groups of 16, which will give you the Word representation of Octal 421.
What is the Long Word representation of Octal 421?
The Long Word representation of Octal 421 is the largest representation of the number in binary form. To convert to Long Word, you will need to follow the same process as converting to Nibble, Byte, and Word, but group the binary digits into groups of 32.
Why is it important to be able to convert Octal numbers to different representations?
Converting Octal numbers to different representations is important because it allows for easier manipulation and storage of data in computer systems. Different representations allow for different levels of precision and can be useful in different types of calculations. Additionally, some programming languages may only support certain representations, so being able to convert between them is necessary for writing efficient code.
