MHB Converting r=4+4cos(theta) into rectangular form
  • Thread starter Thread starter Raerin
    Form Rectangular
To convert the polar equation r=4+4cos(θ) into rectangular form, start with the relationships r²=x²+y² and rcos(θ)=x. The initial equation can be rewritten as √(x²+y²) = 4 + 4(x/√(x²+y²)). This leads to the equation x²+y² = 4√(x²+y²) + 4x after squaring both sides. The conversion process is confirmed to be correct, resulting in a valid rectangular form.
Raerin
So how do I convert r=4+4cos(theta) into rectangular form?
I know that r^2 = x^2+y^2 and that rcos(theta) = x.
Would the start of the solution be:
sqrt(x^2 + y^2) = 4+4x
If yes, I don't know where to go from there.
Mathematics news on Phys.org
sqrt(x^2 + y^2) = 4 +4x
Almost. You have made a small mistake.
We can write $r\cos(\theta) = x$ as
$$\cos(\theta) = \frac x r \qquad\qquad (1)$$
So you should have
$$\sqrt{x^2 + y^2} = 4 + 4 \frac{x}{\sqrt{x^2 + y^2}}$$
This is a correct rectangular form.
That's it. You are done! ;)
To make it a little easier, we can also do (using $(1)$):
\begin{array}{}
r&=&4+4\cos(\theta) \\
r&=&4+4\frac x r \\
r^2&=&4r + 4x \\
x^2+y^2&=&4\sqrt{x^2+y^2} + 4x
\end{array}
Hello, Raerin!
\text{Convert }\,r\:=\:4+4\cos\theta\,\text{ to rectangular form.}
I would do it like this . . .\text{We have: }\:r \:=\:4(1 + \cos\theta)
\text{Multiply by }r\!:\;r^2 \:=\:4(r + r\cos\theta)
\text{Convert: }\:x^2+y^2 \:=\:4\left(\sqrt{x^2+y^2} + x\right)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
