Chemistry Converting scfm to lb/hr, which density should I use?
  • Thread starter Thread starter Frankenstein19
    Density
To convert cubic feet per minute (CFM) to pounds per hour (lb/hr), the actual density of the air at the given conditions must be used, which is 0.61 lb/ft³ at 150 F and 125 psig. For standard conditions, the density is 0.0765 lb/ft³. When converting 500 CFM to standard cubic feet per minute (SCFM), the correct method involves multiplying by the actual density and then converting to lb/hr by multiplying by 60 minutes. The discussion highlights the importance of understanding the difference between CFM and SCFM in these calculations. Accurate conversions rely on the consistent application of mass principles in fluid dynamics.
Frankenstein19
If I convert from cfm to scfm, should I use the density of the material at standard conditions or what the conditions the material is actually at?
lb/hr = cubic feet/min * 60 min/hr * lb/cubic feet
For air for example at conditions 150 F and 125 psig, density is 0.61lb/ft3
At standard conditions it's 0.0765lb/ft3
If I convert 500 cfm to scfm, does this mean I should multiply by 0.0765lb/ft3*60min/hr to convert to lb/hr?
It is not clear to me what are cfm and scfm, never seen these units (I can guess, but I prefer to be sure).
To convert CFM to lb/hr, you multiply by the actual density. To convert lb/hr to scfm, you then divide by the standard density.
In general the only invariant thing in such calculations is the mass.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
