Converting string of dates in Excel
In summary, the intern is trying to figure out a way to convert strings of dates into numerical values and is looking for help. There are three possible solutions, but the intern is unsure how to apply them to the whole string.
QuantumCurt
Education Advisor
726
166
Hey everyone,
This may not be the right place to post this, so if an admin thinks a different section would be better suited, please move this thread.
So I'm in the midst of my summer internship at Fermilab right now. I'm currently trying to plot some data for the beam intensity of the NuMI neutrino beam line. I have long strings of dates of the form (day, month, date, clock time [to thousandths of a second]). For example:
##t_0##=Thu Jun 11 22:04:00.478 and ##t_{final}##=Thu Jun 11 23:03:59.142
When I plot this data in Excel it gets converted to numerical values ranging from 0 to ~2400. What I need to do is drop the day/month/date portion and convert my x-axis to showing values in clock time. Doing this manually isn't an option because I have upwards of 50,000 data points in some of these strings. The various formulas I've found for doing this don't really match up with the date format I have here, so I'm a bit lost.
Any help would be very appreciated!
There are 3 potential solutions:
1) 50000 isn't very much quit being lazy :P
2) Assuming that the DateTimes are in column A put in free column the following formula =RIGHT(A1,12). This will give you a substring of what's in cell A1, giving you the RIGHT most 12 characters. Depending of what you are trying to do you can mix it with LEFT which does the same thing, but gives you the LEFT most characters.
3) Check what the formatting on the cells are. If they are stored as DateTime values as opposed to strings you might be able to just change the cell formatting to a format that will work better.
Hope that helps :)
Likes QuantumCurt
Can you email my mentor and just let him know that I'm going to have to spend the entire summer converting these cells? :-p
This worked! But only for the one cell. Forgive my newbiness, but how do I apply this to the whole string rather than the one cell?
Hope that helps :)
I changed the format and it didn't seem to actually change anything. But my working knowledge of Excel is a bit limited.
Thanks for the help!
There's another column for each entry with the actual data for that time, right?
Is the source data in Excel, or in some other format that you are importing into Excel?
If it's in a text file, you could consider processing that file with C or Tcl or whatever your favorite programming language is, to put the information into a more Excel-friendly format. The resulting file could be in *.csv format, for example, with the data nicely arranged and converted.
If the data is given to you in Excel format, then consider exporting that to a *.csv file, doing the formatting with your program, and re-importing it back into Excel... :smile:
Likes QuantumCurt
Click on the cell where you put the formula. The cell will highlight and there will be a small black box on the lower right corner. Click and hold that and "Drag" down as far as you want the formula.
When you drag up/down excel will update the formulas NUMBER value accordingly. IE it will change A1 to A2, A3, ETC
If you drag left/right it will update the the LETTER. A1 -> B1, C1 etc
If you don't want a value to change put a $ before the value. EG $A$1 won't change. vs $A1 only the number will change.
Hope that helps
Likes QuantumCurt
I'm importing the data from ACNET (Accelerator Control Network here at Fermilab) as an Excel file, and then opening it directly in Excel.
I currently don't have a favorite programming language unfortunately. This summer is really my first experience with any programming. I'm taking an introductory programming course in the fall though, and following it up with a numerical analysis course in the spring. I'm teaching myself a bit of Python this summer (or at least trying to), but I haven't really gotten much beyond 'Hello, World!' yet at this point...lol
What I have is three sets of data. Beam intensity, and measured beam intensity at different points in the beam line. So I have three distinct domains and ranges being plotted on one chart.
Hope that helps
That did the trick! Thank you so much!
Okay, maybe it didn't. This let me convert the columns to just the time, but when I plot it it's still just giving me a range of numerical values from 0-~1400 on the x-axis.
Easy solution!
Right click the chart.
The "Horizontal (Category) Axis Labels" whill be
0, 1, 2, 3 etc
Click on edit
This will give you an "Axis Labels" window.
Beside the text box "Axis label range" is a button with an icon. Click that and it'll return you to the work book. Select the time range column and click that button again.
That should fix it.
Likes QuantumCurt
When I right click the chart I'm not getting an option for "Horizontal Axis Labels".
If I right click the x-axis I get an option for 'Format axis' which gives me fields for minimum and maximum bounds, but it doesn't seem to be letting me change it.
What type of chart did you insert?
Line or Scatter?
Sorry Right click the chart and select "Select Data" first
It's a line chart.
Okay, I went to select data and I'm seeing the screen you're referring to. However, it isn't letting me click on 'edit.' The button is just greyed out.
ETA - It's also telling me that "The data range is too complex to be displayed. If a new range is selected, it will replace all of the series in the Series panel."
QuantumCurt said:
It's a line chart.
Its likely that its a scatter line chart :) They look the same just are handled differently by excel.
Instead on the left select the data series (there should only be 1 based on what you've said)and click "Edit"
Here you'll get a window with 3 boxes. Series Name, Seires X Values and Series Y Values.
Click the bunnon next to X Values and try what I suggested before. You'll likely see that it currently has the orignal values selected not the substring ones
Likes QuantumCurt
Yes, it's a scatter plot with connecting lines.
This is exactly what I did originally. I just copy/pasted the data from the spreadsheet into the Series X and Series Y boxes. The data seems to have been plotted just fine, the labels on the x-axis just aren't correct. It's for some reason assigning a numeric value between 0 and 1400 rather than displaying a time of hh:mm:ss.sss
So I added a custom format to give me labels of "hh:mm:ss.000" and now my x-axis labels are just all saying 00:00:00.000, even though the data all have distinct values that are definitely no 0. I asked my mentor and he didn't know how to change it either.
It seems really odd that I'm having so much trouble with this. This cannot be an uncommon usage of Excel lol
ETA - I set up another sheet with just the first ten data points so I could see how it's behaving. What it's doing is just assigning a number to each point. The first point is 1, the second point was 2, etc.
I guess what I need to figure out is how to change the x-values to the actual data in the cells. It seems incredibly bizarre to me that this isn't working. Excel has always just used whatever values I put into the cells whenever I've used it in the past.
In that case you don't have a scatter chart, you have a line chart. Right-click on the chart, select "Change Chart Type" and select "X Y (Scatter)"
I don't want a scatter plot though. I need a scatter plot with straight connecting lines, which is what I have.
No, you have a what Excel calls a "Line Chart". You do indeed want a scatter chart (which Excel calles an "X Y (Scatter) Chart"), and when you select "Change Chart Type" you can choose the format with lines or add them afterwards.
I just checked again, and the graph type I selected is indeed called "Scatter Plot with Straight Connecting Lines."
In either case, are you thinking that switching to a scatter plot (without straight connecting lines) would resolve this issue? I tried it yesterday and it didn't make any difference aside from removing the straight connecting lines.
In that case it seems you have not selected the x-axis data: this should be "Series 1" with the y-axis data "Series 2".
This is exactly what I've done every time I've tried it.
I tried manually entering a few of the first points into a new chart, and it came up with the correct values on the x-axis. I'm guessing it's related to how I converting the time formatting.
If you are slicing up strings to use as values you need to use e.g. =value(mid(C3,12,5))
Likes QuantumCurt
... but if you are working with times it is probably more difficult than that. Look at the time(), date(), timevalue() and datevalue() functions.
Likes QuantumCurt
If you post some sample data
Code:
as code
I can use it to explain (probably by doing it).
Likes QuantumCurt
Code:
as code
Sorry for the delayed reply. It was a busy weekend.
Here's some sample data. The first column is the date and the time (in military time), and the second column is beam intensity.
Code:
Fri Jun 12 10:03:43.278        32.18554159
Fri Jun 12 10:03:44.611        32.07059549
Fri Jun 12 10:03:45.944        32.04795459
Fri Jun 12 10:03:47.277        32.26913876
Fri Jun 12 10:03:48.610        31.88946829
Fri Jun 12 10:03:49.943        32.03924655
Fri Jun 12 10:03:51.275        31.98873993
Fri Jun 12 10:03:52.608        32.01834726
Fri Jun 12 10:03:53.941        31.87205221
Fri Jun 12 10:03:55.274        31.98873993
I then used the formula =RIGHT(A1,12) to keep only the right 12 digits. I'm thinking this is where things go wrong, because if I manually enter a sample of data points, they come up fine.
I need the time in hh:mm:ss.000, or like this:
Code:
Any help would be greatly appreciated.
After trying out on your data I have discovered you cannot have dates or datetimes or times as column values for an excel scatter chart.
You'll have to convert to an explict line chart, which of course won't allow you to use all the fancy scatter plot functionalities.
I suppose it makes some sense since it doesn't make sense to do a "Best fit" line on a time value.
Likes QuantumCurt
I just tried it with a standard line chart and it did indeed come up with the time values, so I guess I'll just have to stick with that. I don't think I necessarily need all of the scatter plot functionality here, so this should work out fine. Thank you so much! I'm feeling much better now that this is resolved.
However, this is odd. If I take a handful of these values and type the times in manually rather than trying to convert them, the chart comes up with the time as the x-axis values with the proper labels.
With the scatter plot chart? The one thing you'll learn with Excel is that the only consistent thing about it is its inconsistency
Yes, if I manually enter the points I can bring up a scatter plot that displays the actual time values on the x-axis.
I'll keep this inconsistency in mind.
Likes cpscdave
  • #31
With the text in column A, enter this in B1:
Code:
=DATE(2015,MONTH(DATEVALUE("1 "&MID(A1,5,3))),VALUE(MID(A1,9,2)))+TIMEVALUE(MID(A1,12,8))+VALUE(MID(A1,21,3)/24/60/60/1000)
... and this in C1:
Code:
=VALUE(RIGHT(A1,11))
... and copy the formulas down.
This should work, but you will have to play with the x-axis options a bit: you want to set the "Major unit" to 1.15471e-5 (this is the way Excel stores the value 1 s) and with these data set the "Minimum" to 42167.419247685 (this is the value of 10:03:43 on 12 Jun 2015).
If you don't care about what it displays on the axis, it would be easier to ignore the day and just use
Code:
=TIMEVALUE(MID(A1,12,8))*24*60*60+VALUE(MID(A1,21,3)/1000)
to get values in seconds (to 1/1000 s) past midnight.
Likes QuantumCurt
  • #32
That seems to have worked out very well! Thank you much!
Related to Converting string of dates in Excel
1. How do I convert a string of dates in Excel?
To convert a string of dates in Excel, you can use the built-in function called "DATEVALUE". This function takes a string of text that represents a date and converts it into a date value that Excel can recognize and work with. Simply enter the function into a cell and reference the cell containing the string of dates as the argument.
2. Can I convert multiple dates at once in Excel?
Yes, you can convert multiple dates at once in Excel by using the "DATEVALUE" function in combination with the "ARRAY" function. This will allow you to convert a range of dates in one step, rather than converting each date individually.
3. How do I change the date format after converting in Excel?
To change the date format after converting in Excel, you can use the "FORMAT" function. This function allows you to specify the desired date format, such as "mm/dd/yyyy" or "dd-mmm-yyyy". Simply enter the function into a cell and reference the cell containing the converted date as the argument.
4. What if my string of dates contains errors or invalid dates?
If your string of dates contains errors or invalid dates, the "DATEVALUE" function will return an error. To prevent this, you can use the "IFERROR" function to catch any errors and return a blank cell instead. You can also use the "ISERROR" function to check for errors before converting the string of dates.
5. Can I convert dates that are in a different language in Excel?
Yes, you can convert dates that are in a different language in Excel by using the "DATEVALUE" function in combination with the "TEXT" function. The "TEXT" function allows you to specify the language code for the date format, such as "en-US" for English (United States) or "es-ES" for Spanish (Spain).
27K
