MHB Converting to a tri-monthly interest rate
  • Thread starter Thread starter linapril
    Interest Rate
To convert an APR of 3% to a tri-monthly interest rate, the formula used is (0.03 + 1)^(4/12) - 1. This calculation is based on the future value formula for investments, where A represents the future value, P is the principal amount, r is the annual nominal interest rate, n is the number of compounding periods per year, and t is the time in years. In this scenario, r is set to 0.03 and n is 4, reflecting the quarterly compounding. The method ensures accurate conversion of the annual rate to a tri-monthly basis. Understanding this calculation is essential for effective financial planning and investment strategies.
linapril
If the APR is 3%, and I want to find the tri-monthly interest rate, is the correct way to find it:
(0.03+1)^(4/12)-1
Mathematics news on Phys.org
Taken from Wikipedia:
The formula for calculating the future value of an investment having an annual nominal interest rate is:
$\displaystyle A=P\left(1+\frac{r}{n} \right)^{nt}$
where:
  • A = future value
  • P = principal amount (initial investment)
  • r = annual nominal interest rate (as a decimal, not in percentage)
  • n = number of times the interest is compounded per year
  • t = number of years
In your case r = 0.03 and n = 4.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
