Convex hexagon's peculiar property.
In summary, this proof shows that in any convex hexagon, there exists a diagonal that cuts off a triangle with area no more than one sixth of the area of the hexagon.
caffeinemachine
MHB
816
Prove that in any convex hexagon there is a diagonal which which cuts off a triangle with area no more than one sixth of the area of the hexagon.
Mathematics news on Phys.org
Proof: Let ABCDEF be a convex hexagon with area A.
Draw the line segment AD. Let B' and E' be the points on the sides AB and AE respectively such that AB' = BE'.
Let X be the point of intersection of the diagonals BD and CE.
We have a triangle AXB' with area k and a triangle EXB' with area l.
By the law of cosines, we know that the length of AD is given by:
AD^2 = AB^2 + BC^2 - 2AB * BC * cos(∠ABC).
Since AB = BE', we can also write:
AD^2 = 2BE^2 - 2BE * BC * cos(∠ABC).
This implies that AD^2 is independent of the position of B' and E'.
Therefore, the area of the triangle AXB' is independent of the position of B', and likewise the area of the triangle EXB' is independent of the position of E'.
It follows that the total area of the two triangles AXB' and EXB' is constant, and is no more than one sixth of the area A of the hexagon ABCDEF.
Hence, there exists at least one diagonal of the hexagon which cuts off a triangle with area no more than one sixth of the area of
FAQ: Convex hexagon's peculiar property.
What is a convex hexagon?
A convex hexagon is a six-sided polygon with all interior angles less than 180 degrees and all vertices pointing away from the interior of the shape.
What is the peculiar property of a convex hexagon?
The peculiar property of a convex hexagon is that the sum of the lengths of any three consecutive sides is equal to the sum of the lengths of the other three consecutive sides.
How is this property demonstrated?
This property can be demonstrated by drawing a convex hexagon and measuring the lengths of its sides. Then, choose any three consecutive sides and add their lengths together. Repeat for the other three sides. The two sums should be equal.
Is this property unique to convex hexagons?
Yes, this property is unique to convex hexagons. It does not hold true for any other shape.
What are the applications of this property?
This property is useful in geometry and other fields of mathematics. It can also be used in design and construction to ensure that a hexagonal shape is convex and has equal side lengths.
