Convolution Integral Properties
In summary: Could you please explain why you chose the substitution ##\psi=\sigma-\tau+t##? I'm really confused here as I'm not sure how it would help.With this substitution the expression of fresh_42 becomes:$$(F*g) (t) = \int^{\infty}_{-\infty} \left( \left( \int^{t}_{-\infty} f (\underbrace{\sigma-\tau+t}_{\psi}) d \sigma \right) g(t-\tau) \right) d \tau$$I am not sure what properties we need to manipulate the expression above to get to:$$\int^t_{-\infty} \left( \int^{\
roam
1,271
Either by using the properties of convolution or directly from the definition, show that:
If
$$F(t)=\int^t_{-\infty} f (\tau) d \tau$$
then
$$(F * g) (t) = \int^t_{-\infty} (f * g) (\tau) d \tau$$
The convolution of ##f## with ##g## is given by:
$$(f*g)(t) = \int^{\infty}_{-\infty} f (\tau) g(t- \tau) d \tau$$
From definition:
$$(F * g) (t) = \int^{\infty}_{-\infty} \left( \left( \int^t_{-\infty} f (\tau) d \tau \right) . g(t-\tau) \right) d \tau$$
Switching the order of integration:
$$= \int^{t}_{-\infty} \left( \int^{\infty}_{-\infty} f (\tau) d \tau \right) d \tau . \int^{\infty}_{-\infty} g (t - \tau) d \tau$$
So, from here how can I show that this is equal to ##\int^t_{-\infty} (f*g) (\tau) d \tau##?
Because I must show that the expression above is equal to:
$$(F * g)(t) = \int^t_{-\infty} (f*g) (\tau) d \tau = \int^t_{-\infty} \left( \int^{\infty}_{-\infty} f (\tau) g(t-\tau) d \tau \right) d \tau$$
What properties of the convolution integral do I need to use? :confused:
Any help would be greatly appreciated.
If
then
From definition:
From definition I get:
$$(F * g) (t) = \int^{\infty}_{-\infty} F (\tau) g(t- \tau) d \tau = \int^{\infty}_{-\infty} \left( \left( \int^\tau_{-\infty} f (\sigma) d \sigma \right) g(t-\tau) \right) d \tau$$
Likes roam
Did you change the dummy variable ##\tau## to ##\sigma##? So shouldn't we then change all the ##\tau##'s:
$$\int^{\infty}_{-\infty} \left( \left( \int^\sigma_{-\infty} f (\sigma) d \sigma \right) g(t-\sigma) \right) d \sigma$$
How does changing the variable help?
That's not what I wrote. I only replaced the expressions by their definitions. The 'dummy variable' I've changed because the variable of the outer integral is the upper bound for the variable of the inside integral. (Maybe ψ is better to see.)
$$(F * g) (t) = \int^{\infty}_{-\infty} F (\psi) g(t- \psi) d \psi = \int^{\infty}_{-\infty} \left( \left( \int^{\psi}_{-\infty} f (\sigma) d \sigma \right) g(t-\psi) \right) d \psi$$
Likes roam
Thank you so much, it makes perfect sense now.
I have one more question:
Since we finally had:
$$\int^{\infty}_{-\infty} \left( \left( \int^{\tau}_{-\infty} f (\sigma) d \sigma \right) g(t-\tau) \right) d \tau =\int^{\infty}_{-\infty} f (\tau) g (t - \tau) d \tau = (f*g) (t)$$
How do we write this as ##\int^t_{-\infty} (f*g) (\tau) d \tau##? Because I think ultimately this is what the question asks.
Thank you.
$$\int^{\infty}_{-\infty} \left( \left( \int^{\tau}_{-\infty} f (\sigma) d \sigma \right) g(t-\tau) \right) d \tau =\int^{\infty}_{-\infty} f (\tau) g (t - \tau) d \tau$$
The last integral should be $$\int^{\infty}_{-\infty} F(\tau) g (t - \tau) d \tau =F*g(t)$$
so you are back where you started.
To get ##f*g## in the expression given by fresh_42, $$\int^{\infty}_{-\infty} \left( \left( \int^{\tau}_{-\infty} f (\sigma) d \sigma \right) g(t-\tau) \right) d \tau$$ you may try a substitution, and then switching the order of integration.
Your goal is to get to $$\int^t_{-\infty} (f * g) (\tau) d \tau$$
For that you need to get the ##t## in the integration limit, so a substitution should transform ##\sigma=\tau## into ##\psi=t##.
A substitution achieving this is replacing ##\sigma## by ##\psi=\sigma-\tau+t##.
$$\int^t_{-\infty} \left( \int^{\infty}_{-\infty} f (\tau) g(t- \tau) d \tau \right) d \tau = \int^t_{-\infty} (f * g) (\tau) d \tau$$
Any explanation would be really appreciated.
The upper integration limit for ##\sigma## is ##\tau##. In your expected end result, there is a ##t## as upper integration limit.
So my suggested substitution is purely opportunistic: if we set ##\psi=\sigma-\tau+t##, then if ##\sigma=\tau##, ##\psi=t##. That's all really. I'm not saying that I was sure before doing the whole computation that that would help (it really does), but certainly it is a substitution worth the effort.
This is not correct, you get
$$(F*g) (t) = \int^{\infty}_{-\infty} \left( \left( \int^{t}_{-\infty} f (\underbrace{\psi+\tau-t}_{\sigma}) d \psi \right) g(t-\tau) \right) d \tau$$
If you want to rename the integration variable from ##\psi## to ##\sigma##, fine, but then you get
$$(F*g) (t) = \int^{\infty}_{-\infty} \left( \left( \int^{t}_{-\infty} f (\sigma+\tau-t) d \sigma \right) g(t-\tau) \right) d \tau$$
In the expected end result, the integral with ##t## as upper limit is the outside integral. So switch the integration order to get that upper limit where you want it to be.
Then look at what you get. If you don't see it immediately (I didn't), a last substitution ##\mu=t-\tau## will help.
Likes roam
Notice that (not a hint, just a remark):
##\displaystyle F(t)=\int^t_{-\infty} f (\tau) d \tau## implies ##F'(t)=f(t)##.
##\displaystyle (F * g) (t) = \int^t_{-\infty} (f * g) (\tau) d \tau## implies ##(F * g)' (t) =f*g(t)=F'*g(t)##.
So what you are proving in this exercise is the following interesting property of the convolution:
$$(F*g)'(t)=F'*g(t)$$
(provided the functions are sufficiently nice: https://en.wikipedia.org/wiki/Convolution#Differentiation)
Likes roam
Thank you for pointing out the property showing the relationship with differentiation.
But how does the ##u=t-\tau## substitution help at the end?
Because even if we switch the order of integration, the integral with t as the upper limit does not operate on the second term:
$$(F*g) (t) = \int^{t}_{-\infty} \left( \int^{\infty}_{-\infty} f (\psi+\tau-t) d \tau \right) d \psi . \int^{\infty}_{-\infty} g(t-\tau) d \tau$$
$$=\int^{t}_{-\infty} \left( \int^{\infty}_{-\infty} f (\tau) d \tau \right) d \psi . \int^{\infty}_{-\infty} g(t-\tau) d \tau$$
roam said:
Thank you for pointing out the property of the relationship with differentiation.
This is not correct.
From $$(F*g) (t) = \int^{\infty}_{-\infty} \left( \left( \int^{t}_{-\infty} f (\psi+\tau-t) d \psi \right) g(t-\tau) \right) d \tau$$
switching the order of integration gives:
$$(F*g) (t) = \int^{t}_{-\infty} \left( \int^{\infty}_{-\infty} f (\psi+\tau-t) g(t-\tau) d \tau \right)d \psi $$
When you first integrate over ##\tau##, all the terms involving ##\tau## must stay in the interior (first evaluated) integral.
The interior integral should look familiar, possibly after substituting ##\mu=t-\tau##.
Likes roam
Oops, thank you. After the ##\mu=t-\tau## substitution:
$$(F*g) (t) = \int^{t}_{-\infty} \left( \int^{\infty}_{-\infty} f (\psi - \mu) g(\mu) d \mu \right)d \psi$$
And it follows from commutativity:
$$\int^{t}_{-\infty} (g*f) (\psi) d \psi = \int^{t}_{-\infty} (f*g) (\psi) d \psi $$
Is it okay then to change the dummy variable from ##\psi## to ##\tau##? Because in the argument of f in the first equation we have ##\sigma(=\sigma-\tau+t-t+\tau)##, so we can choose ##\sigma## to be any variable?
Yes, the name of the variable you integrate over is totally inconsequential. The only element that you have to keep as is in this exercise is the ##t## (because it appears outside the integral too). All the others: play with their names as much as you like (as long as when you replace a variable name by another, you do it everywhere in the integral, including the integral limits).
Likes roam
Thank you very much for your help.
Related to Convolution Integral Properties
1. What is a convolution integral?
A convolution integral is a mathematical operation that combines two functions to create a new function. It is commonly used in signal processing and image processing to apply a filter or modify a signal.
2. What are the properties of a convolution integral?
The properties of a convolution integral include commutativity, associativity, distributivity, and identity. These properties allow for simplification and manipulation of the convolution integral in order to solve complex problems.
3. How is a convolution integral calculated?
A convolution integral is calculated by multiplying and integrating two functions over a given range. This involves shifting one function over the other and taking the integral of the product at each point of overlap.
4. What is the significance of convolution integral properties in real-world applications?
The properties of convolution integrals are essential in solving problems related to signal processing, image processing, and filtering. They allow for the efficient manipulation and simplification of complex mathematical operations in these fields.
5. Can convolution integral properties be applied to non-linear systems?
Yes, convolution integral properties can be applied to non-linear systems as long as the functions involved are continuous and integrable. However, the properties may not hold for non-linear systems in all cases.
27K
