Convolution of two geometric distributions
In summary: Does the above formula agree with that when ##z = 3##?##P(X+Y = 4) = p(1-p)^2p + (1-p)p^2(1-p) + (1-p)(1-p)p^2 = 3(1-p)^2p^2 ##, Does the above formula agree with that when ##z = 4##?In summary, the conversation discusses deriving the convolution from two geometric distributions and clarifies the correct formula for the summation of the two distributions. The correct formula is $$\displaystyle P \left( X+Y=z \right) \, = \,\sum _{k=2}^{z} \left( 1-p
Ad VanderVen
169
TL;DR Summary
I am trying to derive the convolution of two geometric distributions but obviously I am making an error.
I'm trying to derive the convolution from two geometric distributions, each of the form:
$$\displaystyle \left( 1-p \right) ^{k-1}p$$ as follows $$\displaystyle \sum _{k=1}^{z} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k-1}.$$ with as a result: $$\displaystyle \left( 1-p \right) ^{z-2}{p}^{2}z$$ Now the sum: $$\displaystyle \sum _{z=2}^{\infty } \left( 1-p \right) ^{-2+z}{p}^{2}z.$$ should be equal to ##\displaystyle \frac{2}{p}## which is not the case.
What am I did wrong?
$$\displaystyle \sum _{k=1}^{z} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k-1}$$ seems strange. You sure it's not $$\displaystyle \sum _{k=1}^{z} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k+1}\ ? $$
That indicates that you define the geometric distribution at ##k## to be the probability of success on the ##k##-th attempt, as oppose to the probability of success after ##k## failures.
So , as noted on the stackexchange link, if you consider the sum of two geometric random variables, the smallest possible value of ##k## is 2, which results when you succeed on the 1st try from the first distribution and again on the first try from the second distribution. So it isn't clear why you are writing a summation beginning with ##k = 1##.
I'm afraid you're absolutely right. Only then will you get $$\displaystyle P \left( X+Y=z \right) \, = \,\sum _{k=2}^{z} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k-1}$$
Ad VanderVen said:
The case is treated at: https://math.stackexchange.com/ques...of-two-independent-geometric-random-variables and the summation:$$\displaystyle \sum _{k=1}^{z} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k-1}$$ must be$$\displaystyle \sum _{k=1}^{z-1} \left( 1-p \right) ^{k-1}{p}^{2} \left( 1-p \right) ^{z-k-1}.$$
That formula comes from the message on stackexchange that asked the question and conjectured a formula. Look at the formulas given by the messages that answered the question.
##P(X+Y =2) = p^2##, Does the above formula agree with that when ##z = 2##?
##P(X+Y = 3) = p(1-p)p + (1-p)pp = 2(1-p)p^2 ##
Related to Convolution of two geometric distributions
What is the definition of convolution of two geometric distributions?
The convolution of two geometric distributions is a mathematical operation that combines the probability distributions of two independent geometric random variables. It represents the probability distribution of the sum of the two random variables.
How is the convolution of two geometric distributions calculated?
The convolution of two geometric distributions is calculated by taking the inverse Fourier transform of the product of the Fourier transforms of the two individual distributions. This can also be done by multiplying the probability mass functions of the two distributions.
What are the properties of convolution of two geometric distributions?
The properties of convolution of two geometric distributions include commutativity, associativity, and distributivity. It is also closed under convolution, meaning that the convolution of two geometric distributions is also a geometric distribution.
What are the applications of convolution of two geometric distributions?
The convolution of two geometric distributions has applications in fields such as signal processing, image processing, and probability theory. It is used to model the sum of independent random variables, which is often seen in real-world scenarios.
What is the difference between convolution of two geometric distributions and convolution of two other distributions?
The main difference between convolution of two geometric distributions and convolution of two other distributions is that geometric distributions are discrete, while other distributions may be continuous. This means that the convolution of two geometric distributions will result in a discrete probability distribution, while the convolution of two other distributions may result in a continuous probability distribution.
