Cooling Integrated Circuits with Peltier Cells
In summary, the conversation discusses using peltier cells for both cooling and reading temperature in the same moment. The user has a question about how to measure the cold side of the cell when it is attached to an Integrated Circuit (IC). They plan on using a thermocouple to measure the temperature difference between the hot and cold side. The conversation also mentions using a table to prevent condensation and improving cooling with a fan. The topic of drilling a hole in the PCB to measure the IC's temperature is also brought up. The conversation concludes with a reminder that temperature difference in Kelvin is equivalent to Celsius.
EvIl_DeViL
Hi all,
I have a question about using peltier cells for both cooling and reading temperature in the same moment.
I need to cool down a couple of Integrated Circuits so I'll put put a 20mmx20mm peltier cell over them but I cannot read the cold side of the cell because it's sticked to the IC; I hope physics land me a hand here, providing I put a thermocouple to the hot side...
S = - (Δv/Δt)
where:
S is the Seebeck coefficient (which I'll need for later)
Δv is the voltage I'll read with a multimeter
Δt is thermodynamic temperature which I'll read with a thermocouple. If I understood correctly it should be the difference between the hot and cold side expressed in kelvin's degrees
I'll take all these measurements before placing the peltier over the IC to avoid experimental errors
Now that we found S we place the cell on the IC with some thermal compund and we get:
Δt = - (Δv / S)
hence
Δt = - ((Vin - Vcc) / S)
because I expect Δv across the peltier cell should be Vcc + the voltage generated by the seebeck effect because the cell is in series.
then I convert °K to °C
Now that I have the temperature difference between the hot and cold side I can measure with a thermocouple the hot side, subtract the difference I just found and get the temperature of the cold side sticked to the IC.
Are my assumptions correct? will it work?
I know peltier are dangerous with electronics because of the condense but I recently used a dht11 which is a sensor which can read temperature and humidity.
I'll use it to know how much voltage I can provide to the cell before generating condense using a table like that http://cdn2.i4memory.info/reviewimages/cooling/memory/CorsairDHX_TEC/CorsairDHX_TEC_dewpoint_table.png (I'll drive it with a transistor) to keep it above the dew point (maybe 1 °C with a 5% tollerance).
I also know peltier are cooling better if the hot side is helped in dissipation, my thermocouple will find place between the peltier cell and a fan
Thank you all!
It's the IC you want to cool ( not the peltier cell itself ). The IC is mounted on some PCB ( I guess ), so why don't you drill a hole in the PCB, so that you can measure the temperature of the IC from beneath through this hole? ( I assume that you have not made the layout of the PCB yet ).
It will be much more accurate and simple.
No way; the PCB isn't mine. It's a commercial router (It's called "banana pi bpi-r1" which is a cool piece of hardware but cool in the wrong way eheheh...) so it's multilayer (don't know how many but surely 2 at least: top and bottom). Also some ICs are BGA so drilling is a no go :( It's an official fact that using sata + wifi + external usb + high cpu load would result in hardware fault and shortened life (his, not mine luckily) because of the high current walking around (almost 3 Amps) and the poor AXP209 (PMU) is heavy loaded!
Nice advice though! If I'll ever project a board I'll consider a hole under the hottest ICs for this purpose.
returning to physics: I can't believe nobody didn't ever tried something similar before. There must be something on the web!
Alternately, attach a thin piece of aluminum between the IC and the Peltier cell, and have it stick out a little past the cell on one side. Attach your thermocouple to that tab of Al that is sticking out... :smile:
EvIl_DeViL said:
Hi all,
S = - (Δv/Δt)
where:
Δt = - (Δv / S)
hence
Thank you all!
For some reason, people seem to forget that a temperature difference of 1 degree Kelvin = 1 degree Celsius. o_O
If you measure temperatures in degrees Celsius, no conversion is necessary when calculating the temperature difference. :wink:
I know but the library of the thermocouple sensor throw out celsius values so we still have to convert so I can sum. I can also convert my sensor values from °C to °K that's not the problem :)
@berkeman: I'd like something more professional/accurate and which make me feel a genius :D I think my idea could work and I came here just to have a confirmation before even wasting time on it :P
Related to Cooling Integrated Circuits with Peltier Cells
What is a Peltier cell?
A Peltier cell, also known as a thermoelectric cooler, is a type of solid-state device that uses the Peltier effect to create a temperature difference by transferring heat between two electrical junctions. It is commonly used for cooling integrated circuits.
How does a Peltier cell cool integrated circuits?
A Peltier cell works by utilizing the Peltier effect, where an electric current is passed through a circuit made of two different types of conductors. This creates a temperature difference between the two junctions, causing one junction to cool down and the other to heat up. By placing one junction on the integrated circuit, the heat is transferred away, effectively cooling the circuit.
What are the advantages of using Peltier cells for cooling integrated circuits?
Peltier cells have several advantages for cooling integrated circuits, including their compact size, low power consumption, and ability to provide precise temperature control. They also have no moving parts, making them more reliable and durable compared to other cooling methods.
What are the limitations of using Peltier cells for cooling integrated circuits?
One limitation of using Peltier cells for cooling integrated circuits is their low coefficient of performance, meaning they require a significant amount of energy to produce a small amount of cooling. They also have a limited heat pumping capacity, making them less suitable for cooling high-power circuits.
What are some considerations when using Peltier cells for cooling integrated circuits?
When using Peltier cells for cooling integrated circuits, it is important to consider the power requirements, thermal management, and compatibility with the circuit's voltage and current specifications. It is also essential to properly insulate and seal the Peltier cell to prevent any condensation or moisture buildup that could damage the circuit.
