Coordinate based vs non-coordinate based differential geometry
In summary: I don't know... people who want to know about differential geometry. In summary, this book provides a coordinate-free approach to differential geometry.
Mike706
51
Hello Everyone,
I am just wondering what the difference in these is. Could someone please give a brief example of non-coordinate based differential geometry vs the equivalent in coordinate based, or explain the difference (whichever is easier)? Also, what advantages does one have over the other?
Thanks for your help,
Mike
Edit - Also, are there specific names for these two types of DG? Thanks again.
Hi,
There is no difference btw coordinate-free DG and coordinate DG. They are the same thing (namely, DG!) but viewed from two different perspective. The situation is exactly analogous to coordinate free linear algebra vs coordinate linear algebra. For instance, given an abstract vector space V, the coordinate-free approach sees a linear operator T:V-->V as a map s.t. T(ax+by)=aTx+bTy. The coordinate approach results from choosing a basis v1,...,vn of V, which sets up an isomorphism with R^n via v_j -->e_j. Then a linear operator T:V-->V is one such that in coordinates, if x=(x1,...,xn), then
[tex]
(Tx)_i=\sum_{j=1}^na_{ij}x_j.
[/tex]
for some set of n² numbers a_ij.
Whereas the coordinate approach of linear algebra arises from the non-coordinate one from choosing a basis for V, likewise the coordinate approach of DG arises from the non-coordinate one from choosing a coordinate system on the manifold M.
In DG as in linear algebra, sometimes it is preferable to work in the coordinate free approach either because it conveys the ideas of what's going on more transparently, or because the computations are easier/less messy to carry out. And some other times the same holds true of the coordinate approach over the coordinate free approach.
Mike706 said:
Hello Everyone,
Mike
Geometric structures can be described globally without reference to coordinates. However they can always be expressed locally in a coordinate system. In the 18'th century and maybe earlier I am not sure, geometers described curves and surfaces by parameterizations and then deduced the geometry from the parameters. This is a coordinate approach to geometry. But later is was realized that geometries exist as global structures across an entire surface and that the surface can not necessarily be described with a single coordinate system.
I can describe examples if you like.
Thank you for the quick replies!
quazar987:
That made a lot of sense, I think I understand it now. Could you just confirm my understanding please? I am using this book. It uses Clifford algebra instead of differential forms.
-In the beginning of the book, the basis vectors were described explicitly in terms of matrices. The main purpose this is done, it is stated, is to show concretely that we can actually use matrices to form a linearly independent basis of the required degree. So using this basis is then coordinate-based DG.
-In chapter 4 the author just said we will not consider any more explicit matrices, and also states without proof (beyond scope of the book) that it is possible to define Clifford numbers without matrices at all. So we will no longer consider matrix products, but Clifford products. This is then the coordinate-free approach, since we are not considering any specific basis anymore.
Am I correct?
Edit - Actually, I'm not so sure that was correct, now that I think about it further. Would it be possible for you to provide a simple concrete example?Lavinia:
Thank you for the reply as well. I've heard that said before in the past and have been very curious about it. However, I only started studying DG within the last few weeks so I have not come across it yet. I would definitely be interested in an example.
Thanks again
MikeEdit - Formatting
I am not familiar with this version of DG, but what you wrote makes sense to me.
Lavinia:
Edit - Formatting
I recommend Singer and Thorpe's book, Lecture Notes on Elementary Geometry and Topology. the section on Differential Geometry uses the modern approach that starts with a connection 1 form on the tangent unit circle bundle of the surface. It later shows how this coordinate free method can be translated into the classical theory of parameterized surfaces in Euclidean 3 space. This is not a graduate level book. It is for beginners.
It made sense to me, as well. But it was wrong :P.
Lavinia I think you just answered about 3 of my questions with what you said after recommending the book. Things clicked - it was good. I will definitely check out that book as well, thanks.
Related to Coordinate based vs non-coordinate based differential geometry
What is the difference between coordinate based and non-coordinate based differential geometry?
Coordinate based differential geometry is a branch of mathematics that studies curves and surfaces in a coordinate system, using coordinates to describe geometric objects and their properties. Non-coordinate based differential geometry, on the other hand, uses intrinsic properties of geometric objects, such as curvature and distance, to study them without the need for a coordinate system.
Which approach is more commonly used in differential geometry?
Coordinate based differential geometry is more commonly used in practical applications, as it allows for easier calculations and visualization of geometric objects. However, non-coordinate based differential geometry is gaining popularity, particularly in fields such as general relativity, where the concept of spacetime is better understood without the use of coordinates.
What are the advantages of non-coordinate based differential geometry?
Non-coordinate based differential geometry allows for a deeper understanding of geometric objects and their properties, as it focuses on intrinsic properties rather than relying on a coordinate system. It also allows for the study of more abstract or complex geometric objects that may not have a straightforward coordinate representation.
How do coordinate based and non-coordinate based differential geometry relate to each other?
Coordinate based and non-coordinate based differential geometry are not mutually exclusive, as both approaches can be used to study geometric objects. In fact, many concepts and theorems in non-coordinate based differential geometry have their origins in coordinate based methods.
What are some real-world applications of coordinate based and non-coordinate based differential geometry?
Coordinate based differential geometry has a wide range of applications, including computer graphics, robotics, and physics. Non-coordinate based differential geometry is commonly used in fields such as differential equations, topology, and geometry processing.
