Coordinate transformation of contravariant vectors.
In summary, the conversation discusses the coordinate transformation equation for contravariant vectors and the need for two indices in the equation. The first equation uses summation over all unprimed components while the second equation represents a single component and is not equivalent. It is mentioned that the second index provides additional information and the need for two indices is explained.
trv
73
Note: The derivatives are partial.
I've seen the coordinate transformation equation for contravariant vectors given as follows,
V'a=(dX'a/dXb)Vb
What I don't get is the need for two indices a and b. Wouldn't it be adequate to just write the equation as follows?
V'a=(dX'a/dXa)Va
The prime being adequate to indicate the new and the unprimed the old, coordinates and contravariant vector. Or does the second index provide some more information which I am unaware of?
The first equation has on the LHS a single component of V' while the RHS is a sum by summation convention over all the unprimed components.
[tex]V'^1 = \frac{\partial X'^1}{\partial X^1}V^1 + \cdots + \frac{\partial X'^1}{\partial X^n}V^n\\
\vdots
V'^m = \frac{\partial X'^m}{\partial X^1}V^1 + \cdots + \frac{\partial X'^m}{\partial X^n}V^n
[/tex]
Your equation is a single component and represents no sum, so it is not equivalent.
\vdots
V'^m = \frac{\partial X'^m}{\partial X^m}V^m[/tex]
It seems to state that the ath component of V' depends only on the ath component of V, which is usually not the case.
Ok thanks, that makes sense now.
Related to Coordinate transformation of contravariant vectors.
1. What is a contravariant vector?
A contravariant vector is a mathematical concept used in vector calculus to represent the change in a quantity with respect to a coordinate system. It is a type of vector that transforms in the opposite direction of the coordinate transformation.
2. Why is coordinate transformation of contravariant vectors important?
Coordinate transformation of contravariant vectors is important because it allows us to express physical laws and equations in different coordinate systems, making it easier to solve complex problems and analyze different scenarios.
3. How is a contravariant vector transformed under a coordinate transformation?
A contravariant vector is transformed by multiplying it with the Jacobian matrix, which represents the change in coordinates from one system to another. This transformation ensures that the vector maintains its direction and magnitude in the new coordinate system.
4. Can contravariant vectors be transformed between non-orthogonal coordinate systems?
Yes, contravariant vectors can be transformed between non-orthogonal coordinate systems. The Jacobian matrix used for the transformation takes into account the non-orthogonality of the coordinate systems.
5. What are some real-world applications of coordinate transformation of contravariant vectors?
Coordinate transformation of contravariant vectors has various applications in fields such as engineering, physics, and computer graphics. It is used to analyze the motion of objects in different reference frames, simulate fluid flow, and create 3D models and animations.
