Copying from /usr/local/bin to /usr/bin?
  • Thread starter CAF123
In summary, it is possible to copy or move an executable from /usr/local/bin to /usr/bin, but this requires root permissions. If you are using a Linux shell, you can type sudo cp /usr/local/bin/gfortran/ /usr/local/bin or sudo ln -s /usr/local/bin/gfortran/ /usr/bin/ to make the symbolic link.
  • #36
Thanks, I get the following
Code:
.CFUserTextEncoding
.DS_Store
.Trash
.bash_history
.bash_profile
.bash_profile~
.bash_sessions
.config
.cshrc
.dropbox
.emacs.d
.kshrc
.profile
.ssh
.subversion
.vim
.viminfo
Desktop
Documents
Downloads
Dropbox
Library
Movies
Music
Pictures
Public
plus other personal files. I've tried to write export PATH="/Users/myname/Downloads/LoopTools-2.14/x86_64-Darwin/bin:$PATH" in the file .bash_profile but still I can't get the Install["LoopTools"] to run.
Thanks!
Technology news on Phys.org
  • #37
Can you check which executable files there are in that x86_64-Darwin/bin directory?
And then type:
Code:
which whatever-executable-file-without-path
Then try again with:
Code:
tcsh
  • #38
There is a LoopTools executable, fcc one and lt one.
And then type:
Code:
OK, does this just tell me the path to the executable files?
Code:
tcsh
This came with an error saying LoopTools: command not found
  • #39
Yes. It means your terminal can find the executable.
Okay. Let's try editing your .cshrc and add the line:
Code:
set path=($path $HOME/Downloads/LoopTools-2.14/x86_64-Darwin/bin)
and try again.
If it works, please log out and back in before starting Mathematica.
  • #40
So do you mean to say just write in the line
Code:
set path=$path $HOME/Downloads/LoopTools-2.14/x86_64-Darwin/bin
in the terminal? (The brackets you had seem to give me an error but when taking them out it seems to work)
I logged out and back in but mathematica still says it can't find the MathLink executable (same error as before)
  • #41
Code:
No, it should be added to the file /Users/yourname/.cshrc, and I believe it should include the parentheses.
Just to check that it is correct can you execute:
Code:
tcsh
which LoopTools
  • #42
Ah I see, ok I added that line to the file .cshrc and then executed the three lines above. Nothing happened but I guess that was to be expected. So, I think it is ok. I logged out but mathematica still gives the same error.
Edit: Could I not try writing the same thing in .bash_profile? But indeed I see that the manual suggests .cshrc
Just going for some food now, but thanks a lot for your help so far!
  • #43
Which file to use depends on whether you're using the Bash shell (.bash_profile) or the C shell (.cshrc).
  • #44
I like Serena said:
The usual shell on a Mac is 'bash' instead of 'tcsh' if I'm not mistaken.
And the corresponding configuration file is $HOME/.bashrc instead of $HOME/.cshrc .
So I think we need to modify the .bashrc instead.
I had to look up the difference between .bashrc and .bash_profile (which is what I use).
From here: https://apple.stackexchange.com/que...he-difference-between-bash-profile-and-bashrc
When you login (type username and password) via console, either sitting at the machine, or remotely via ssh: .bash_profile is executed to configure your shell before the initial command prompt.
But, if you’ve already logged into your machine and open a new terminal window (xterm) then .bashrc is executed before the window command prompt. .bashrc is also run when you start a new bash instance by typing /bin/bash in a terminal.
On OS X, Terminal by default runs a login shell every time, so this is a little different to most other systems, but you can configure that in the preferences.
Likes I like Serena
  • #45
No, unfortunately it's not okay that nothing happened. 'which LoopTools' should either print the path to it, or give an error that it cannot find it.
So I'm currently at a loss why this doesn't happen.
Btw, be careful how you add the line with the PATH.
.bash_profile and .cshrc are incompatible, and completely independent from each other.
How do you start Mathematica exactly?
Can you start it from within the terminal?
Is it a tcsh script? Or something else?
I can understand. ;)
  • #46
Hi again :)
Ah sorry, I realized I misinformed you yesterday that nothing happened - when I typed in which LoopTools indeed I got the path to it.
I see, so if I add the same path in both files then this leads to problems?
I just opened up mathematica from finder and done it within a mathematica notebook. I don't think I've opened mathematica up using the terminal before. Since we've followed all the instructions given in the manual perhaps the way I'm starting mathematica is incorrect - somehow it doesn't know about the addition of the new path perhaps.
