Coriolis force on rotating plane
In summary: This means that the object will accelerate with a non-zero tangential component of acceleration. The force the plane exerts upon the object is equal in magnitude and opposite in direction to the Coriolis force. When the object is sliding along the bottom sheet the Coriolis force will be zero, but the force of constraint will be normal to the sheet, so the object will accelerate upward. The equations of motion can be found by considering Newton's second law in the x and y directions, and using the constraint of constant radial velocity in the rotating system. In summary, a particle of mass m is confined to move, without friction, in a vertical plane, with axes x horizontal and y vertically up. The plane is forced
Ayotte
A particle of mass m is confined to move, without friction, in a vertical plane, with axes x horizontal and y vertically up. The plane is forced to rotate with constant angular velocity [tex]\Omega[/tex] about the y axis. Find the equations of motion for x and y, solve them, and describe the possible motions.
Fcor=2m v [tex]\times[/tex] [tex]\Omega[/tex]
This is listed in a section of the homework titled "The Coriolis Force." However, when I think about the problem, the only fictitious force that I can see applying here is centrifugal. Any motion in the y direction will be parallel with Omega, and therefore the cross product will be zero, and any motion in the x direction will cause the cross product to be in the z direction. I'm confused, because the problem is in the section where the problems should involve the Cor. force, so I would like confirmation that I'm correct.
You are right, the Coriolis force has no effect in the x,y plane.
ehild
Take a simpler case first:
A horizontal tube, in which an object can slide without friction, the tube is rotating with constant angular velocity. Let the object be released at some distance to the central axis of rotation.
Obviously in that case the object will start sliding away from the axis of rotation.
The tube constitutes a rotating system. As the object gains radial velocity the wall of the tube must exert a force upon the object to keep it co-rotating.
The formula [tex]F = 2mv \times \Omega [/tex] expresses how much tangential acceleration (wrt the rotating system) there will be if there is no force upon the object.
Without a force an object moving away from the central axis will start to fall behind the rotating motion. But in this case the tube prevents the object from "falling behind"; buildup of tangential velocity (wrt the rotating system) is prevented, so the force that the tube exerts upon the object will be equal to and opposite in direction to the fictitious Coriolis force.The problem you describe can be seen as an object that can slide frictionless between two sheets. The two sheets are vertical.
Release an object from the top, from a point that is some distance away from the central axis. Gravity will accelerate the object downward, and the constraint of co-rotating with the vertical, rotating plane will cause the object to accelerate outward.
Related to Coriolis force on rotating plane
1. What is the Coriolis force?
The Coriolis force is a fictitious force that appears to act on objects moving on a rotating plane. It is caused by the rotation of the Earth and causes objects to deflect to the right in the Northern Hemisphere and to the left in the Southern Hemisphere.
2. How does the Coriolis force affect weather patterns?
The Coriolis force plays a significant role in the formation of weather patterns. It deflects winds and ocean currents, causing them to move in a curved path. This leads to the formation of high and low-pressure systems, which are essential for the development of storms and other weather events.
3. Can the Coriolis force affect the trajectory of a projectile?
Yes, the Coriolis force can affect the trajectory of a projectile, particularly for long-range shots. In the Northern Hemisphere, it causes projectiles to deflect to the right, while in the Southern Hemisphere, it deflects them to the left. This effect is most significant for objects moving at high speeds or over long distances.
4. How does the Coriolis force impact the rotation of hurricanes?
The Coriolis force is a crucial factor in the formation and intensity of hurricanes. As warm air rises and rotates in a cyclonic motion, the Coriolis force deflects it, causing the hurricane to spin and grow in size. Without the Coriolis force, hurricanes would not be able to develop and maintain their strength.
5. Can the Coriolis force influence the direction of ocean currents?
Yes, the Coriolis force plays a significant role in the direction of ocean currents. In the Northern Hemisphere, it causes ocean currents to deflect to the right, while in the Southern Hemisphere, it deflects them to the left. This effect is essential for the circulation of nutrients and heat in the ocean, which affects marine life and weather patterns.
