Corollary 8: Integration in 'Polar Coordinates'
In summary: Your Name]In summary, Sergio is seeking clarification on integrating forms on manifolds in Spivak's Differential Geometry Vol. 1. He is unsure about the existence of the term (-1)n-1 in the corollary mentioned in chapter 8 and is looking for help to understand its purpose. The term (-1)n-1 is important in considering orientation on a manifold, and it is necessary to take into account both orientations in higher dimensions. Fubini's theorem is justified in this case, but the term (-1)n-1 can also be added when interchanging integrals to account for a change in orientation.
LightKage
I am reading Spivak's Differential Geometry Vol. 1. I am stuck for some days in chapter 8 about integrating forms on manifolds. Maybe someone can clear my doubt.
First, I will 'type' what the corollary says:
My doubt is regarding this affirmation:
The book it says is easy to see. Well I think the (-1)n-1, does not exist. I worked in the n=2 case just to see where I was doing an error, but still I have that negative sign does not exist.
I will post my working out:
http://postimg.org/image/ghfrg9jq1/
I believe Fubini is justified. A good person that was trying to help me, said that instead of Fubini, I can only interchange the integrals adding the (-1)n-1 term, but I don't know why.
Any help is appreciated,
thanks
Sergio
Dear Sergio,
Thank you for reaching out for help with your doubt about integrating forms on manifolds in Spivak's Differential Geometry Vol. 1. I understand that you have been stuck on this topic for a few days and are looking for clarification on the corollary mentioned in chapter 8.
In order to help you better, I would first like to clarify the affirmation that you are having doubts about. From what I understand, you are questioning the existence of the term (-1)n-1 in the corollary. I would like to assure you that this term does indeed exist and is an important factor in the integration of forms on manifolds.
To understand why this term exists, it is important to understand the concept of orientation on a manifold. Orientation refers to the direction in which a curve or surface is traversed, and it plays a crucial role in integration of forms. In the n=2 case, as you have worked out, the negative sign may seem to not exist because you are considering only one orientation. However, in higher dimensions, it becomes necessary to consider both orientations.
Fubini's theorem is indeed justified in this case, but as your friend mentioned, you may also interchange the integrals by adding the term (-1)n-1. This is because when you interchange the integrals, the orientation of the manifold changes, and the term (-1)n-1 takes into account this change in orientation.
I hope this helps to clear your doubt. If you still have any further questions or need more clarification, please do not hesitate to ask. Keep up the good work in studying Spivak's Differential Geometry and best of luck with your studies!
FAQ: Corollary 8: Integration in 'Polar Coordinates'
What is the definition of integration in polar coordinates?
Integration in polar coordinates is a method of finding the area under a curve in a polar coordinate system. It involves converting the polar coordinates into rectangular coordinates and then using the standard integration techniques to find the area.
How do you convert a polar equation to a rectangular equation?
To convert a polar equation to a rectangular equation, you can use the following formulas: x = r cosθ and y = r sinθ, where r is the distance from the origin to the point and θ is the angle from the positive x-axis to the point.
What is the difference between polar and rectangular coordinates?
Polar coordinates use a distance and an angle to locate a point, while rectangular coordinates use two perpendicular lines (x and y axes) to locate a point. Polar coordinates are often used to represent circular or curved shapes, while rectangular coordinates are better for representing lines or angles.
How do you find the area under a curve in polar coordinates?
To find the area under a curve in polar coordinates, you can use the formula A = ½∫[f(θ)]^2 dθ, where f(θ) is the polar equation and the integral is taken over the interval of θ values that correspond to the desired area.
Can you use the Pythagorean Theorem in polar coordinates?
No, the Pythagorean Theorem only applies to right triangles in rectangular coordinates. In polar coordinates, the distance from the origin to a point can be found using the formula r = √(x^2 + y^2), which is derived from the Pythagorean Theorem, but the theorem itself cannot be used directly in polar coordinates.
