Correct formula to use for potential difference?
In summary, the conversation discusses the correct formula for calculating potential difference using the given equations and diagrams. The formula is V2 - V1 = ΔV = - E*Δs, where Δs is the distance between two points and E is the force on a 1 Coulomb charge. The conversation also clarifies that the force is negative and points in the opposite direction of Δs.
outxbreak
30
My book can't stick to one formula EVER.
In Q7 They start off using: E = −ΔV Δs (equation 20-4)
Then magically go to: ΔV = EΔs
Where is the negative sign because it never states to find the magnitude of the potential difference
http://img198.imageshack.us/img198/6914/msbn.jpg
I don't see how ΔV is directionless because in problem 3 it takes on the negative sign
http://img90.imageshack.us/img90/6047/pa9.gif
You copied one of the equations wrong: you wrote " E = - ΔV Δs. "
Here's the story: (vectors in bold)
the correct formula is V2 - V1 = ΔV = - Es where Δs is defined positive pointing from point 1 to point 2
and E is the force on a 1 Coulomb charge anywhere between points 1 and 2.
BUT: the 1 coulomb charge is assumed to not affect the given E field. So, more correctly,
E = limit as q → 0 of (force on a positive charge q)/q.
Example: capacitor plates with positive voltage on plate 2 and negative voltage on plate 1.
s points from plate 1 to plate 2.
ΔV = V2 - V1 = -Es > 0.
where Δs is positive since we're going from 1 to 2.
So E = - ΔV/Δs which would be negative. The force on a small positive test charge q is always qE so the force is negative and points in the direction opposite to Δs.
FAQ: Correct formula to use for potential difference?
What is the formula for potential difference?
The formula for potential difference is V = W/Q, where V is the potential difference in volts, W is the work done in joules, and Q is the charge in coulombs.
How is potential difference different from voltage?
Potential difference and voltage are often used interchangeably, but they are slightly different concepts. Potential difference refers to the difference in potential energy between two points in an electric field, while voltage is the measurement of this difference in units of volts.
Can potential difference be negative?
Yes, potential difference can be negative. This means that the direction of the electric field is opposite to the direction of the charge's motion.
What factors affect the potential difference in a circuit?
The potential difference in a circuit is affected by the amount of work done on the charges, the amount of charge present, and the characteristics of the material through which the charges are moving.
How do I calculate potential difference in a circuit?
To calculate potential difference in a circuit, you can use the formula V = IR, where V is the potential difference, I is the current in amps, and R is the resistance in ohms. You can also use the formula V = W/Q, where W is the work done and Q is the charge in coulombs.
