Correct me if I am wrong
  • Thread starter Jarvis Bull Dawg
In summary: OK,show it for n=7 because I don't think it works for n=7.In summary, we have proven that for any odd integer n greater than 5, the expression n^2-25 is always divisible by 8. This was done through mathematical induction, using the base case of n=1 and the hypothesis that the expression is true for n=2k+1. However, it was also shown that induction is not necessary for this proof and it can be solved using algebraic manipulation. Additionally, we have shown that the last two digits of 7^201 are 07 based on the pattern of the last two digits
Jarvis Bull Dawg
Prove that of 25 is subtrated from the square of an odd integer greater than 5, the resulting number is always divisible by 8.
Solution:
Let S (n) = n2 – 25
For n = 1, S (1) = (1 )2 – 25 = -24 which is clearly divisible by 8.
Thus the first condition is satisfied as S(1) is true.
Let us assume that S(n) is true for n = 2k+1 Belonging to Odd integers greater than 5, that is,
S(2k+1) = (2k+1)2 - 25 is divisble by 8
= 4k2 + 4k + 1 -25
= 4k2 + 4k - 24
= 4(k2 + k - 6)
= 4(k-2)(k+3) ------ (A)
We can see that (A) is clearly divisible by 8, condition being that k is an odd integer which is bigger than 5. Since both conditions are satisfied, hence by mathematical induction we have proven that S(n) is divisble by 8 for all integers bigger than 5.
Mathematics news on Phys.org
umm, you are not exactly correct. you are setting n = to 2k + 1. while that is denoting an odd integer, that is what n should be and you have not shows for n+1 yet which should be 2k + 3.
however, induction doe snot require that you use that form. you can simply say n for all n = 2k+1, now showing for n+1 and just use n+1 to show it rather than 2k+3
Jarvis Bull Dawg said:
Let S (n) = n2 – 25
Why is your base case n=1 when you're trying to prove this for odd integers greater than 5?
= 4k2 + 4k + 1 -25
= 4k2 + 4k - 24
= 4(k2 + k - 6)
You don't use your induction hypothesis here, and you don't need to. Induction is not necessary.
n>5, not k.
True. Thank you :smile:
What should I use?
Next thing, so should I use k+1 rather than 2k+1? Advice?
What should I use?
2k+1 is good, n is an odd integer after all. You don't know if k is even or odd though.
use what you've got:
n^2-25
=(2k+1)^2 - 25
= 4k^2 + 4k + 1 -25
= 4k^2 + 4k - 24
= 4(k^2 + k - 6)
Show A is divisible by 8. 2 cases if you like, k even or k odd.
Actually the n>5 bit isn't necessary, it's just to keep n^2-25 positive, the concept of divisibility still makes sense for negative integers.
By the way you can use Latex to make exponents [tex]n^{2}[/tex] <-click to see how, or please use a ^ to denote exponentiation as I've done above, as "n2" looks like another variable or the variable n times 2. :smile:
Odd integers greater than 5: 7, 9, 11...
(5+2), (5+4), (5+6)...
general form: (5+2n), n=1,2,3...
So, what number are you looking at? (5+2n)^2 minus something? Do some algebra here...
Until you're done. (hint: factor out '2's when you can...)
There's no need for induction. If you must, start with n=7, not n=1 (factoring negative integers is uncool).
I think it is easier solved this way
(n^2)-25 divides 8 is equivalent to
(n^2)-1 divides 8 because 24 divides 8
now we have
(n-1) (n+1) divides 8
n= 2 m + 1 ( n is odd as suggested in the problem)
(2 m ) (2 m + 2 ) = 4 m (m+1)
if m is even we are done , if m is odd then (m+1) is even .Both cases prove
divisibility by 8
Here is another one, but seriously I have no idea what this is.
Observe that the last two digits of [tex]7^2[/tex] are 49, the last two digits of [tex]7^3[/tex] are 43, the last two digits of [tex]7^4[/tex] are 01, and the last two digits of [tex]7^5[/tex] are 07. Prove that the last two digits of [tex]7^201[/tex] are 07.
what are the last two digits of [tex]7^6[/tex]? [tex]7^7[/tex]? Notice a pattern?
Suggestion:[tex]7^{4}=100k+1[/tex] for some integer k. Use this to show that the last two digits of [tex]7^{4n}[/tex] are 01 for any natural number n.
Yes I do notice the recurring pattern, but I didn't get your suggestion.
Knowing [tex]7^{4}=100k+1[/tex] you should be able to prove you can write [tex]7^{4n}=100m+1[/tex] where m is some integer (for example use the binomial theorem).
This will prove that the last two digits of [tex]7^{200}[/tex] are 01. (Since you're only interested in this case you could really take n=50 above, but it doesn't really simplify things)
By the way, you're not familiar with modular arithmetic are you? While not necessary to do problems like this, it does simplify things.
Edited for errors
Hope yo get it. I solved it for the 201 term. By B-Theorem
I tried to do it this way
By binomial theorem I find the last two terms are
(10-3) ^ 201 = (201) (10) (3 ^ 200 )- (3) ^ 201
or
(3 ^ 200) (2010 - 3)
or
(9^100) (2000+7) =((10-1)^100 )( 7) since we are concerned with the last two digits
or
7(1000 t +1)
7000 t +7
This proves the last two digits are 07
You're solutions are perhaps correct but you fail to proove the generality of this statement (for any therm). The true solution is much simpler...
Any odd number greater than 5 can be writtent under the form 5+x, where x is even. Following the statement:
(5 + x)^2 - 25
25 + x^2 + 2(5)x - 25
x^2 + 2(5)x.
Since x is even, let x=2y
(2y)^2 + 2(2)(5)y
4y^2 + 4(5y)
4(y^2 + 5y)
y^2 + 5y is even for any integrer. So let y^2 + 5y=2a
4(2a)
8a
This is the proof that the solution for (5 + x)^2 - 25, where x is even is always a factor of 8.
FAQ: Correct me if I am wrong
What does "Correct me if I am wrong" mean?
"Correct me if I am wrong" is a phrase often used to express uncertainty or to invite others to correct any mistakes or misunderstandings. It is a way of acknowledging that one's own understanding may not be completely accurate and asking for clarification or correction.
Is "Correct me if I am wrong" a polite way of asking for correction?
Yes, this phrase is typically seen as a polite and respectful way of inviting others to provide feedback or correct any mistakes. It conveys a sense of openness to learning and improvement.
When should I use "Correct me if I am wrong" in a conversation or discussion?
This phrase can be used anytime you want to clarify your understanding or invite others to provide feedback. It can be particularly useful in situations where you are unsure of something or want to make sure everyone is on the same page.
If someone says "Correct me if I am wrong", does that mean they are admitting they are wrong?
Not necessarily. While this phrase can be used to acknowledge a potential mistake, it can also simply be a way of inviting others to share their perspective or knowledge. It does not always indicate that the person saying it believes they are wrong.
Can "Correct me if I am wrong" be considered a form of humility?
Yes, this phrase can be seen as a way of humbly acknowledging that we may not have all the answers and inviting others to contribute to the conversation. It shows a willingness to learn and grow, which is an important aspect of humility.
