Correct proof (in stewart calculus) of fermat's theoram ?
  • Thread starter Thread starter ManishR
    Calculus Proof
The discussion centers on the proof of Fermat's theorem as presented in Stewart's calculus. The author attempts to demonstrate that if a function f has a maximum or minimum at point c, then the derivative at that point must equal zero. However, the response clarifies that the author's approach incorrectly equates the derivative of f(c) with the derivative of the function at c, leading to a misunderstanding. The correct interpretation involves recognizing that the derivative is defined as the limit of the difference quotient, which approaches a specific value L as h approaches zero. Ultimately, if c is a maximum or minimum, the limit L must equal zero, confirming that the derivative at that point is indeed zero.
ManishR
the proof of http://en.wikipedia.org/wiki/Fermat%27s_theorem_%28stationary_points%29" from stewart calculus is in the pdf.
In short, the author has done something like this,
consider,
m\leq0
\Rightarrow\frac{m}{n}\leq0
so
\frac{m}{n}\leq0 if n>0 .....[1]
and
\frac{m}{n}\geq0 if n<0 .....[2]
from inqualties [1] & [2]
\frac{m}{n}=0
\Rightarrow m=0
which is incorrect because in
n of [1] =/= n of [2]
correct proof
Fermat Theoram Statement:
If
f(c)\geq f(c+k) OR f(c)\leq f(c+k) where a-c\leq k\leq b-c
Then
\left[\frac{df(x)}{dx}\right]_{x=c}=0
Proof:
\left[\frac{df(x)}{dx}\right]_{x=c}=\frac{df(c)}{dx}
\Rightarrow\left[\frac{df(x)}{dx}\right]_{x=c}=\frac{dM}{dx} where M=f(c)
\Rightarrow\left[\frac{df(x)}{dx}\right]_{x=c}=lim_{h\rightarrow0}\frac{M(x+h)-M(x)}{h}
\Rightarrow\left[\frac{df(x)}{dx}\right]_{x=c}=lim_{h\rightarrow0}\frac{0}{h} because M(x+h)=M(x)
\Rightarrow\left[\frac{df(x)}{dx}\right]_{x=c}=0
so question is am i right ?
Your proof is incorrect. \left[ \frac{df}{dx}\right]_{x=c} is NOT the same thing as differentiating f(c). The latter will give zero no matter what point c is, because f(c) is just a constant. What you calculated is the derivative of f(c) on the right side of each of those equalities
The idea is that the derivative must be equal to the one sided limit as h goes to zero of \frac{f(c+h)-f(c)}{h}. For very small values of h, this is going to be close to some number L.
If c is a maximum, then when h is positive the fraction that we have is positive, so it must be that L is larger than or equal to zero (because L IS the limit). On the other hand, if h is negative the fraction that we have is negative, so it must be that L is smaller than or equal to zero.
So we have 0 \leq L \leq 0 which implies that L, which is f'(c), is zero.
  • · Replies 16 ·
