Correct understanding of the tension force
In summary: The tension force is equal to the traction vector dotted with the unit vector in the direction of the rope, multiplied by the cross-sectional area of the rope. In summary, tension is a force that is derived from the stress tensor and relates the diagonal tensor components to an infinitesimal area perpendicular to the tension force direction. The tension force can be found by calculating the traction vector, which is equal to the stress tensor dotted with the unit outwardly directed normal to the area. The traction vector is then multiplied by the area to find the tension force.
fog37
1,568
108
Hello,
I am reviewing the concept of tension, a force that expresses the internal tensional state in a body (rope, chain, string, solid body). My understanding is that the force of tension "derives" from the stress tensor and relates (it is the product) the diagonal tensor components to an infinitesimal area ##dA## perpendicular to the tension force direction pointing away from the area.
  • The stress tensor diagonal components are scalars (they are essentially what we call pressure, I guess, and when positive, they are used to derive tension). If the rope lies along the x-axis, then there is only one of nonzero diagonal components which multiplied by the rope cross-section, results in the tension force, correct?
  • In general, a "true" vector is one that is uniquely defined in both magnitude and direction at a point in space. Inside a rope under tension, the tension force is always directed axially and at an arbitrary point ##P## inside the rope seems to point in two opposite directions at the same time...Is that because, considering an imaginary cut at point ##P##, adjacent pieces of the rope have zero relative motion and experience an action-reaction force pair? The piece of rope to the left of the imaginary cut experiences a force pointing to the right and the piece of rope on the right of the cut experience a left directed force...Is that correct?
Thank you!
Thank you!
Imaginary Cut
As far as the imaginary surface, I guess there could be two ways to look locally at the rope and its state of tension:
a) The infinitesimal segment ##M## of the rope located exactly at the imaginary transverse cut is pulled by the two neighboring rope segments ##A## and ##B## with equal and opposite forces, equal to the tension, stressing the middle segment ##M##.
b) There is not rope segment at the cut, just a rope segment to the left and a rope segment the right of the imaginary cut. Each segment is pulled by the other segment with a force, the tension (force). The two forces are equal in magnitude and opposite in direction.
Stress tensor
The Cauchy symmetric stress tensor pertains to internal surface forces (not body forces). Surface forces are shear forces and tension/compression forces. In a real (not massless) rope with its entire length along the x-axis under tension, the tension varies along the rope and the stress tensor is a field tensor with components that vary with x.
The traction vector t(n) for a given current position x acts on an arbitrarily oriented surface element characterized by an outward unit normal area vector n. In our simple example, the normal vector n points along the x-axis. The traction vector t(n), which is a linear combination of the stress tensor components, comprises both shear and perpendicular effects. The traction is a vector has units N/m^2.
I am still confused on how to get the tension force T, which is a force and has units of N, from the traction vector t(n). Are the almost the same thing? Do I just multiply the traction vector t(n) by the infinitesimal area ##dA##: ## T= t(n) dA##?
The traction vector acting on an area is equal to the stress tensor dotted (contracted) with the unit outwardly directed normal to the area. This is the force exerted by the material on the side of the area toward which the unit vector is pointing and on the material on the side of the area from which the unit normal vector is pointing. So, if you have a rope aligned along the x axis, the traction vector on the right side of a cross section is equal to the stress tensor dotted with ##\mathbf{i_x}##; the traction vector on the left side of the cross section is equal to the stress tensor dotted with ##(-\mathbf{i_x})##. So the two traction vectors have opposite signs, as required by Newton's 3rd law. If the area is not oriented normal to one of the principal stress directions, there is also a shear (tangential) component to the traction vector.
Likes vanhees71 and fog37
Thank you Chestermiller.
So once we find the traction vector, the tension force is simply the traction vector multiplied by the area...
Likes vanhees71
Yes.
Related to Correct understanding of the tension force
1. What is tension force?
Tension force is a type of force that occurs when an object is pulled or stretched. It is a result of the interactions between the molecules or atoms within the object.
2. How is tension force different from other types of forces?
Tension force is different from other types of forces, such as compression force, because it acts in the opposite direction. While compression force pushes or squeezes an object, tension force pulls or stretches it.
3. What factors affect the magnitude of tension force?
The magnitude of tension force is affected by the strength of the material, the amount of force applied, and the distance over which the force is applied. It also depends on the angle at which the force is applied.
4. Can tension force be both positive and negative?
Yes, tension force can be both positive and negative. A positive tension force occurs when the object is being stretched, while a negative tension force occurs when the object is being compressed.
5. How is tension force important in everyday life?
Tension force is important in many everyday activities, such as tying a knot, playing a musical instrument, or even walking. It is also crucial in engineering and construction, where it is used to support structures and distribute weight.
  • Mechanics
10K
