Correct Use of the Parallel Axis Theorem for Moment of Inertia
The discussion focuses on the correct application of the Parallel Axis Theorem for calculating the moment of inertia. The user initially calculates the moment of inertia for a rod in two cases but arrives at incorrect values, particularly for the second case with arms stretched. The error stems from not properly applying the theorem, specifically neglecting to use the moment of inertia about the center of mass. After clarification, the user acknowledges the mistake and realizes the need to incorporate the correct formula. Accurate application of the theorem is essential for obtaining the correct moment of inertia values.
simphys
In order to increase her moment of inertia about a vertical axis, a spinning figure skater stretches out her arms horizontally; in order to reduce her
moment of inertia, she brings her arms down vertically along her sides. Calculate the change of moment of inertia between these two configurations of the arms. Assume that each arm is a thin, uniform rod of length 0.60 m and mass
2.8 kg hinged at the shoulder at a distance of 0.20 m from the axis of rotation.
xD
so calculated, the moment of inertia for a rod about an axis at the end of the rod is I = 1/3 * M * L^2
here for case 1: arms to the side
I is calculated to be ##I = 0.224##
for case 2: arms stretched
## I = 1 / 3 * M * L^2 + M * d^2 ## with L = 0.6 m (length of rod) and d = 0.2 (dinstance from 'hinge' to axis of rotation)
## I = 0.896## is my answer.
Yet the actual answer is ##I = 1.568##. I don't really understand what I am doing wrong here so can someone help me please?
Reasoning:
In case 2 I basically have the moment of inertia at the end (the 'hinge'/shoulder so to say) and need to add a dinstance d to get the moment of inertia about the rotation axis via the parallel axis theorem yet this isn't correct.
Thanks in advance
You have not used the parallel axis theorem correctly. $$I = I_{\rm cm} + md^2$$ What does ##I_{\rm cm}## mean?
What does ##d## mean?
Likes simphys and hutchphd
yeah apologies it should have been 2 times the symbolic equation, just forgot to type it out.
Omg... totally forgot that... thanks a lot... I needed to use the moment of inertia about the center of mass basically..,.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
