bagasme
- 79
- 9
I have asked this question on Stack Exchange: SE question.
I often encountered this sticker on most motorbikes (especially matic ones) [credit: cintamobil.com]:
There, when the tire pressure was measured from cold condition, the tire pressure are same regardless of loadout (29 psi and 33 psi for front and rear tire respectively).
According to SE:
Is it true that tire pressure and loadout (e.g. riders) correlate with acceleration of motorbike? Are there any papers that explain about it?
Regards, Bagas
According to SE:
The acceleration of the bike is given by the torque of the engine and the mass of the bike plus passengers - so when you have a passenger, there is greater inertia to overcome and your acceleration will be less
The force of friction is typically (naively) modeled by Ff∝μN
, whether static or kinetic (while both of these forces are vectors, the normal force acts perpendicular to the surface while friction acts in some direction parallel to the surface). If engine/gearbox can put enough torque on the axle to spin the wheels out, then the acceleration is capped not by the drive-train, but by the friction between the drive wheel(s) and the road.
Most tire manufacturers recommend a tire pressure which balances the durability of the tire's sidewall and the increased gas mileage of an over-inflated tire with the added comfort, acceleration and braking of a slightly less inflated tire (see rolling resistance). Obviously, tires either too flat or too full are a safety hazard.
If the engine/gearbox are powerful enough, the center mass hasn't moved too high and the connection between the road and the wheels exceptionally tight, one could see greater acceleration with a passenger.
Regards, Bagas
