Correspondence Theorem for Groups .... Another Question ....
In summary, the Correspondence Theorem for Groups is a fundamental concept in group theory that explains the relationship between subgroups and quotient groups. It works by mapping subgroups of a given group onto subgroups of its quotient group, based on the cosets of the subgroup. This theorem is significant because it allows us to study subgroups by examining simpler quotient groups and has applications in various fields. It can be applied to all groups as long as they meet certain conditions. Some real-life applications of this theorem include its use in quantum mechanics, chemistry, and computer science.
Math Amateur
MHB
3,998
48
I am reading the book: "Advanced Modern Algebra" (Second Edition) by Joseph J. Rotman ...
I am currently focused on Chapter 1: Groups I ...
I need help with an aspect of the proof of Proposition 1.82 (Correspondence Theorem) ...
Proposition 1.82 reads as follows:
In the above proof by Rotman we read the following:
" ... ... To see that ##\Phi## is surjective, let ##U## be a subgroup of ##G/K##. Now ##\pi^{-1} (U)## is a subgroup of ##G## containing ##K = \pi^{-1} ( \{ 1 \} )##, and ##\pi ( \pi^{-1} (U) ) = U## ... ... "My questions on the above are as follows:
Question 1
How/why is ##\pi^{-1} (U)## is a subgroup of ##G## containing ##K##? And further, how does ##\pi^{-1} (U) = \pi^{-1} ( \{ 1 \} )## ... ... ?
Question 2
How/why exactly do we get ##\pi ( \pi^{-1} (U) ) = U##? Further, how does this demonstrate that ##\Phi## is surjective?
Help will be much appreciated ...
Peter
Hi Peter
Question 1:
The preimage of a subgroup of the codomain is always a subgroup of the domain. Try to prove this using the characterisation of subgroups
(i.e., show that ##\pi^{-1}(U) \neq \emptyset## and ##a,b \in \pi^{-1}(U) \implies ab^{-1} \in \pi^{-1}(U)##)
##K \subseteq \pi^{-1}(U)## because ##K = \pi^{-1}(\{1\}) = \pi^{-1}(\{e_{G/K}\})##
Question 2:
Furthermore, for any surjective function:
##\pi(\pi^{-1}(U)) = U##.
Try to prove this (set theory question, has nothing to do with groups)
This shows that ##\Phi## is surjective, because you took an arbitrary ##U## subgroup of ##G/K## and then show that ##\Phi(\pi^{-1}(U)) = \pi^{-1}(U)/K =\pi(\pi^{-1}(U)) = U##.
Note that it is important here that ##\pi^{-1}(U)## contains ##K##, otherwise the quotient is not well defined.
Thanks Math_QED ... appreciate your help and support...
Just now reflecting on what you have written ...
Peter
Hi Math_QED ...
Taking up your suggestion ...We have that ##U## is a subgroup of ##G/K## ...
Want to show that ##\pi^{-1} (U) \neq \emptyset## and that ##a,b \in \pi^{-1} (U) \Longrightarrow ab^{-1} \in \pi^{-1} (U)##Now ...
##\pi( 1_G ) = 1_{ G/K } \Longrightarrow \pi^{-1} ( 1_{ G/K } ) = 1_G##
##\Longrightarrow \pi^{-1} (U) \neq \emptyset##Now ...
... let ##a, b \in \pi^{-1} (U)##
##\Longrightarrow \pi(a), \pi(b) \in U##
##\Longrightarrow \pi(a), [ \pi(b) ]^{-1} \in U## since ##U## is a subgroup ...
##\Longrightarrow \pi(a), \pi( b^{-1} ) \in U## since ##\pi## is a homomorphism ...
##\Longrightarrow \pi(a) \pi( b^{-1} ) \in U## since ##U## is a subgroup ...
##\Longrightarrow \pi( a b^{-1} ) \in U## since ##\pi## is a homomorphism ...
##\Longrightarrow a b^{-1} \in \pi^{-1} (U)## ...
Therefore ##\pi^{-1} (U)## is a subgroup of ##G## ...Is that correct ...?
Peter
Yes, it is.
Likes Math Amateur
Math Amateur said:
Hi Math_QED ...
##\Longrightarrow \pi^{-1} (U) \neq \emptyset##Is that correct ...?
Peter
The idea is correct, but the line
doesn't make sense. The preimage is a set, and can't be equal to something that isn't a set. Even if you would have written ##\{1_G\}##, it wouldn't be correct though.
Notice that ##\pi^{-1}(1_{G/K})## is shorthand notation for ##\pi^{-1}(\{1_{G/K}\})##. We are not talking about inverse functions here.
You should rather write ##\pi(1_G) = 1_{G/K} \in U##, which means that ##1_G \in \pi^{-1}(U)##. Can you explain me why ##1_{G/K} \in U##? This is essential here.
The rest is correct.
Likes Math Amateur and fresh_42
Related to Correspondence Theorem for Groups .... Another Question ....
1. What is the Correspondence Theorem for Groups?
The Correspondence Theorem for Groups is a fundamental concept in group theory that explains the relationship between subgroups and quotient groups. It states that there is a one-to-one correspondence between subgroups of a given group and the subgroups of its quotient group.
2. How does the Correspondence Theorem for Groups work?
The Correspondence Theorem for Groups works by mapping subgroups of a given group onto subgroups of its quotient group. This mapping is based on the cosets of the subgroup in the given group and the cosets of the subgroup in the quotient group. The cosets are used to determine the structure and properties of the subgroups in both the given group and its quotient group.
3. What is the significance of the Correspondence Theorem for Groups?
The Correspondence Theorem for Groups is significant because it provides a powerful tool for understanding the structure of groups. It allows us to study subgroups of a given group by examining the subgroups of its quotient group, which can often be simpler and easier to understand. This theorem also has applications in other areas of mathematics, such as abstract algebra and geometry.
4. Can the Correspondence Theorem for Groups be applied to all groups?
Yes, the Correspondence Theorem for Groups can be applied to all groups, including finite and infinite groups, as long as the groups satisfy the necessary conditions for the theorem to hold. These conditions include having a normal subgroup and being a quotient group of the given group.
5. Are there any real-life applications of the Correspondence Theorem for Groups?
Yes, the Correspondence Theorem for Groups has real-life applications in various fields, such as physics, chemistry, and computer science. For example, it is used in quantum mechanics to study the symmetries of particles, and in chemistry to analyze molecular structures. In computer science, this theorem is used in creating efficient algorithms for data compression and error correction.
  • Linear and Abstract Algebra
