MHB Cos^2(∠POA)+cos^2(∠POB)+cos^2(∠POC)+cos^2(∠POD) is independent of P.
  • Thread starter Thread starter lfdahl
    Independent
The expression \(\cos^2(\angle POA) + \cos^2(\angle POB) + \cos^2(\angle POC) + \cos^2(\angle POD)\) is shown to be independent of the point \(P\) on the unit sphere. By selecting specific vertices of the inscribed cube and calculating the cosine values based on the coordinates of \(P\), it is demonstrated that the resulting sum simplifies to a constant value of \(\frac{4}{3}\). This result holds regardless of the position of \(P\) on the sphere, confirming the independence of the expression from \(P\). The calculations utilize the properties of dot products and the geometry of the cube and sphere. Ultimately, the discussion reinforces the mathematical relationship between the angles and the fixed geometric structure.
lfdahl
MHB
A cube is inscribed in the unit sphere $x^2 +y^2 +z^2 = 1$. Let $A,B,C$ and $D$ denote the
vertices of one face of the cube. Let $O$ denote the center of the sphere, and $P$
denote a point on the sphere. Show that
\[\cos ^2(\angle POA)+\cos ^2(\angle POB)+\cos ^2(\angle POC)+\cos ^2(\angle POD)\]
is independent of $P$.
Mathematics news on Phys.org
[sp]
Let us write $S$ for the expression, and $R$ for the radius of the sphere. As $S$ is dimensionless, it is independent of $R$, and we may choose $R$ as we want.
We take the vertices as $A=(1,1,1)$, $B=(-1,1,1)$, $C=(1,-1,1)$ and $D=(-1,-1,1)$; this makes $R=\sqrt3$.
Let the coordinates of $P$ be $(x,y,z)$. We have:
$\cos POA = \dfrac{\langle OA\cdot OP\rangle}{R^2} = \dfrac{x + y + z}{3}$
and a similar expression for the other terms ($\langle\cdot\rangle$ is the dot product).
This gives:
$$\begin{align*}
S &=\frac19\left((x+y+z)^2 + (-x+y+z)^2 + (x-y+z)^2 +(-x-y+z)^2\right)\\
&= \frac49\left(x^2+y^2+z^2\right)
\end{align*}
and, as $x^2+y^2+z^2=R^2 = 3$, we get $S=\dfrac43$, which is indeed independent of the position of $P$.
[/sp]
castor28 said:
[sp]
and a similar expression for the other terms ($\langle\cdot\rangle$ is the dot procuct).
This gives:
$$\begin{align*}
\end{align*}
[/sp]
Thankyou, castor28 for such a nice solution and for your participation!(Handshake)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
