ChrisVer
- 464
Give [itex]q(t)[/itex] the deceleration parameter, as a function of:
[itex]\Omega_{\Lambda}[/itex],
the cosmological constant density,
and
[itex]\bar{a}(t) = \frac{a(t)}{a(t_{0})}= 1+ H_{0} (t-t_{0}) - \frac{1}{2} q_{0} H_{0}^{2} (t-t_{0})^{2} [/itex]
where [itex]a[/itex]'s the scale factors
have already defined [itex] τ = H_{0}t [/itex] time parameter, and showed:PLEASE DON'T GIVE SOLUTION (I will repeat it at the end)
I just want to reconfirm my result at first stage.
[itex]q(t)= -\frac{1}{H^{2}} \frac{\ddot{a}}{a} [/itex]
[itex] \frac{1}{\bar{a}} \frac{d \bar{a}}{dτ}= \frac{H}{H_{0}}[/itex]
[itex] H^{2} + \frac{k}{a^{2}} = \frac{ \rho_{\Lambda}}{3M_{Pl}^{2}} [/itex]
I made the observation that [itex]q(t)[/itex] is given by:
[itex] q(t) \propto \frac{1}{H^{2}} \frac{dH}{dt} [/itex]
proof:
[itex] \frac{dH}{dt} = \frac{\ddot{a}}{a} - \frac{\dot{a}^{2}}{a^2} [/itex]
so
[itex] \frac{1}{H^{2}} \frac{dH}{dt} = \frac{1}{H^{2}} (\frac{\ddot{a}}{a} - H^{2})[/itex]
the first term is [itex]-q(t)[/itex]. The second term is 1...
[itex] \frac{1}{H^{2}} \frac{dH}{dt} = -q(t) -1 [/itex]
[itex] q(t)= -1 - \frac{1}{H^{2}} \frac{dH}{dt} [/itex]
So far I think I didn't lose any step... Then I take Friedman equations, and have:
[itex] \frac{H^{2}}{H_{0}^{2}} = \Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}} [/itex]
or:
[itex] H=H_{0} \sqrt{ \Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}}} [/itex]
I take its derivative wrt to t:
[itex]\dot{H} = \frac{1}{2} \frac{H_{0}}{\sqrt{ \Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}}}} \frac{2k \dot{a}}{H_{0}^{2} a^{3}} [/itex]
[itex]\dot{H} = \frac{ H k}{H_{0} a^{2} \sqrt{ \Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}}}}[/itex]
I insert this to the equation I got for [itex]q(t)[/itex], one H is going to be canceled:
[itex] q(t)= -1 - \frac{ k}{ H_{0} a^{2} H \sqrt{ \Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}}}}[/itex]
and using again that [itex]H[/itex] is the same square root multiplied by [itex]H_{0}[/itex]:
[itex] q(t)= -1 - \frac{k}{H_{0}^{2} a^{2} (\Omega_{\Lambda} - \frac{k}{H_{0}^{2}a^{2}})}[/itex]
Now I can generally determine [itex]k[/itex] from taking the Friedman equation today.
[itex] \frac{k}{H_{0}^{2} a_{0}^{2}} = \Omega_{\Lambda} - 1 [/itex]
[itex] \frac{k}{H_{0}^{2} a^{2}} = \frac{\Omega_{\Lambda} - 1}{\bar{a}^{2}} [/itex][itex] q(t)= -1 - \frac{\Omega_{\Lambda} - 1}{\bar{a}^{2}} \frac{1}{\Omega_{\Lambda} - \frac{\Omega_{\Lambda} - 1}{\bar{a}^{2}}} [/itex]
[itex] q(t)= -1 + \frac{1- \Omega_{\Lambda}}{(\bar{a}^{2}-1) \Omega_{\Lambda} +1} [/itex]
Do you see any flaw?
Am I always possible to define [itex]a_{0}=1[/itex] in order to make it disappear?
