I Cosmological Scalar Field Density Dilution
A homogeneous free scalar field with mass m and a quadratic potential exhibits oscillations at frequency m when the mass is much greater than the Hubble parameter (m ≫ H). The discussion emphasizes the importance of neglecting Hubble friction, allowing the scalar field to behave as an underdamped oscillator. The energy density of the scalar field is derived from the Klein-Gordon equation, leading to the conclusion that it dilutes as a^{-3} after inflation ends. This relationship is confirmed by averaging the energy density over time and applying the appropriate equations of motion. The analysis highlights the dynamics of scalar fields in cosmological contexts, particularly during inflationary phases.
Samama Fahim
Consider a homogeneous free scalar field ##\phi## of mass m which has a
potential
$$V(\phi) = \frac{1}{2}m^2\phi^2$$
Show that, for ##m ≫ H##, the scalar field undergoes oscillations with
frequency given by $m$ and that its energy density dilutes as
##a^{−3}##.
This is from Modern Cosmology, Scott Dodelson, Chapter 6.
For the part "Show that its energy density dilutes as ##a^{−3}##", following is my attempt:
In the equation ##\frac{\partial \rho}{\partial t} = -3H(P+\rho)##, put ##P = \frac{1}{2} \dot{\phi}^2-V(\phi)## and ##\rho=\frac{1}{2} \dot{\phi}^2+V(\phi)## to get
$$\frac{\partial \rho}{\partial t} = -3\frac{\dot{a}}{a}\dot{\phi}^2,$$
where ##H = \dot{a}/a##. I am not sure how to proceed or proceed or whether this is the correct approach. Should I use Friedmann's equation instead? But it involves densities of other species as well, and there is no assumption here whether one species dominates. Or Should I convert ##d\rho/dt## to ##d \rho/ da##?
Kindly provide a hint as to how to proceed.
Space news on Phys.org
Sorry, going through my replies and must have missed this at the time...
The paper goes into some detail but you can proceed in a more simple way.
Recall from the Klein Gordon equation for the inflation,$$\ddot{\phi} + 3H\dot{\phi} + V' = 0$$The key assumption is to neglect the Hubble friction, ##3H\dot{\phi} \ll 1##, i.e. you have an underdamped oscillator when ##m## is large. We are given that the potential is quadratic (this would also apply for small oscillations around any quadratic minimum), so you have ##V' = m^2\phi## and the equation of motion ##\ddot{\phi} + m^2 \phi = 0## is just SHM with frequency ##m##. So write, for example,$$\phi = \phi_0 \cos{m t}$$For the next part, you have the right idea,$$\dot{\rho} = -3H(\rho + P) = -3H \dot{\phi}^2 $$Finally you just look at the time average. Note ##\langle \dot{\phi}^2 \rangle = \frac{1}{2} m^2 \phi_0^2 = \langle \rho \rangle##, so you just get$$d \ (\log \langle \rho \rangle) = -3 \ d (\log a)$$which then spits out the ##\rho \sim a^{-3}## dependence after inflation ends.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
