Could 0.9c neutron star jets originate from the core?
In summary, the article suggests that a neutron star jet with a velocity greater than 0.9c may be caused by a mix of ultra-relativistic core material escaping the star. However, the process required to produce this jet is still unknown, and further research is needed to determine whether or not this is truly a jet.
Bernie G
330
Could neutron star jets with velocity greater than 0.9c be caused by a mix of ultra-relativistic core material escaping the star? See this link:
http://www.dailygalaxy.com/my_weblog/2015/08/neutron-star-jets-near-speed-of-light-rival-those-of-black-holes.html
Astronomy news on Phys.org
That would require some unknown high energy reaction that is sufficient to push the matter against the gravity of the star, against the drag and weight of the outer layers, and still have enough left over so that known processes can accelerate the mass to the very high speeds mentioned.
This is: as opposed to an unknown high energy process that only needs to accelerate the mass from close to the surface, little drag, less gravity etc to fight?
Next step is usually Occam's Razor.
Do you have any information besides the article in the link?
This is: as opposed to an unknown high energy process that only needs to accelerate the mass from close to the surface, little drag, less gravity etc to fight? Next step is usually Occam's Razor. Do you have any information besides the article in the link?
“That would require some unknown high energy reaction that is sufficient to push the matter against the gravity of the star, against the drag and weight of the outer layers, and still have enough left over so that known processes can accelerate the mass to the very high speeds mentioned.”
The simplest process I can think of would be the disintegration of a nucleus into quark and lepton particles that have a total rest mass under about 10 MeV and an original kinetic energy of about 930 MeV.
“Do you have any information besides the article in the link?”
No, I’m focusing on just PSR J1023+0038. With conventional explanations neutron star jets should not be >0.5c. One would think an article about a neutron star jet >0.9c would have attracted more attention. Maybe the information in the link is erroneous. That would be a bummer!
Another factor, quoting from Wikipedia: “One of the best ways of exploring how jets are produced is to determine the composition of the jets at a radius where they can be directly observed. For example, if a jet originates in the accretion disc, its plasma is likely to have electron-ion composition, whereas if it originates in the black hole it will likely be electron-positron in nature.”
Also if jets do not always occur simultaneously with accretion it’s a red flag about how jets are produced.
... but it still has to get through the outer layers with enough of that energy to count ... you realize quarks don't exist by themselves. The closest you'll get is a quark-gluon plasma. So you still have trouble with Occam's razor here: why can't the jet come from the surface layers? You have the same amount of speculative hand waving and fewer obstacles.
One of the reasons for studying these things is that they are basically a really big nucleus ... held together by gravity mostly... so here we have the intersection of a QM object with a gravitational object. The intersection of QM and gravity remains a mystery so: very interesting.
Note: please do not use wikipedia as a starting point to formulating novel theories.
What you are doing is basically speculation. I think there are rules about speculation around someplace.
The short answer to your original question is "nobody knows: there is not enough information".
Why does this neutron star have a jet? Its moving at least 5 million mph so how can it be accreting? A young neutron star shedding excess mass might be an explanation. Does anybody have a suggestion?
5Mmph is a bit under 1% the speed of light, and 10x the speed of the Solar System. Why would traveling this fast mean it does not have a jet? Remember that all reference frames are equal, so, if it is OK for a stationary neutron star to jet, the same mechanism should work for a moving one. The article you cite does not seem to think the jet is at all unexpected.
Note: is 5 million mph fast? Sounds fast ... but it's an inconvenient number so let's convert a bit:
5000000mph is 1390mps, or 2360kmps, or 0.007c
Well it's not relativistic (##\gamma = 1.00002##)
To compare such slow objects, kmps (kilometer's per second) would normally be used.
(If you want to explore astrophysics more, you should get used to the metric system.)
The Solar system is traveling about 240kmps
The escape velocity of the Milky Way is 317kmps
The fastest star in the MIlky way, though, is doing: 1200kmps (2700000mph)
... so yes, that's pretty fast for a star.
But this should also give you a feel for the kinds of numbers to expect.
According to conventional understanding the jet mechanism is supposed to originate from accretion. How can this neutron star be accreting? It has no binary companion. Is an accreting cloud being dragged along with it? This high speed star has had a jet for over a thousand years. There is some stuff the neutron star is dragging along but its probably from the jet. I think the powerful jet is heating the stuff around the star.
In other stationary neutron stars, jet heating of the accretion cloud could explain why the Eddington limit is sometimes exceeded.
You just suggested two mechanisms for the star having a jet just by considering what the stationary mechanism is.
Remember that the speeds given in these articles are usually given with respect to the galactic center of mass ... though sometimes with respect to the Solar system. But we know the galactic center of mass is moving with respect to the center of mass of the local galactic cluster... so all neutron stars are in motion. All the ones you are thinking of as "stationary" are moving, and "dragging" an accretion disk with them - just like the Sun "drags" the Solar System with it. Maybe it has a close binary companion - too close to resolve just yet? Maybe some jets can persist for thousands of years apart from the companion?
... did you check to see if the radiation is consistent with an accretion mechanism?
What I am trying to do here is get you talking in astrophysical terms ... i.e. you've been talking as if these velocities are somehow absolute. There is no such thing as an absolute velocity and I'm sure you've heard of this.
But all you have is a load of "I don't know"s being the best answer.
Feel free to speculate but remember: coming up with new and novel physical theories is easy - supporting them is hard.
Closed pending moderation.
Edit: several more speculative posts have been removed and the thread will remain closed.
Related to Could 0.9c neutron star jets originate from the core?
1. What is the significance of 0.9c in relation to neutron star jets?
The value of 0.9c refers to the speed of the jet, which is 0.9 times the speed of light. This is a very high velocity and indicates that the jet is traveling at almost the speed of light.
2. How are neutron star jets formed?
Neutron star jets are formed by the intense magnetic and gravitational forces present in the core of a neutron star. These forces can accelerate particles to high speeds, creating powerful beams of radiation that are emitted from the poles of the star.
3. What evidence supports the idea that 0.9c neutron star jets originate from the core?
There are several pieces of evidence that support this idea. First, observations of neutron stars have shown that they have strong magnetic fields, which are necessary for jet formation. Additionally, the high speeds and energy of the jets are consistent with the intense conditions in the core of a neutron star.
4. Can neutron star jets travel faster than 0.9c?
No, according to Einstein's theory of relativity, nothing can travel faster than the speed of light. The value of 0.9c indicates the maximum speed that these jets can reach.
5. What is the potential impact of studying 0.9c neutron star jets?
Studying these jets can provide valuable insights into the extreme conditions present in the core of a neutron star. It can also help us understand how these jets affect their surroundings, such as the interstellar medium, and how they contribute to the larger processes of galaxy formation and evolution.
  • Astronomy and Astrophysics
10K
