Could a bubble shield at L1 combat global warming?
In summary, MIT scientists believe they may have discovered a solution to reversing climate change by reducing insolation through a solar shade that would cool the planet without significantly affecting fossil fuel production. However, there are concerns about the potential negative impact on sunlight-dependent processes and the high cost of implementing such a solution. Other proposed solutions include selective reflective screening and painting surfaces white, but these also have potential drawbacks. Some suggest that reducing consumption and implementing more realistic and peaceful solutions may be more effective in addressing global warming.
Astronomy news on Phys.org
If you read the homepage of the MIT group, it is a bit less sensational than the article you linked - labelling it an ”emergency solution if things have gone too far”.
In general, blocking out sunlight seems counter productive as sunlight is ultimately the source of renewable energy, directly in the case of solar power and indirectly in the case of driving winds and waves. Blocking the Sun would therefore seem to increase reliance on other sources such as fossil fuels. The exception here being fission or fusion power if the fuel can be extracted in an environmentally friendly and efficient way.
Likes Maarten Havinga, sophiecentaur, russ_watters and 1 other person
We need the phytoplankton in the Southern Ocean to convert excess CO₂ into biomass and O₂. Blocking sunlight would be counterproductive to recovery, as would harvesting the krill that eat the phytoplankton, or killing the whales that eat the krill.
Whales recycle the limited iron to fertilise the next generation of phytoplankton, and so the wheel turns, powered by sunlight. We need the iron cycle in the Southern Ocean to become a runaway success.
Likes Maarten Havinga, sophiecentaur, 256bits and 1 other person
It's not about completely blocking off the sunlight. I'm not sure why the responses above seem to assume so.
You reduce insolation by a small percentage, and that's enough to both cool the planet and keep the sunlight-dependent processes going - albeit at a somewhat slower rate/efficiency than otherwise. But it's talking about a couple percent reduction in insolation. For most purposes other than global temperature balance nothing would change.
It (solar shade) is also not a new idea, other than in details of engineering and placement.
I don’t think either of us assumed that. You seem to be making assumptions.
I think the percentage matters here, and the take doesn't necessarily work. How much would insolation need to be reduced in order to stop the temperature rise? 1%? That would have little impact on fossil fuel production and no adverse feedback.
The project homepage mentioned 1.8% iirc.
Even if the sunshade is partial, the effect on the environment in places where it's needed would still be pro-rata.
You'd have to accept that the "bubble" would cost an awful lot in resources so why not target the shading to places around the Earth where less sunlight would only be of benefit? Selective (and adjustable) reflective screening could reduce local heating in desert areas. I have suggested, several times, that whitewashing roofs, rocks and bare mountains would have only good effects. Apart from "the cost", there have been no significant objections. But that cost would be a tiny fraction of the Boris Johnson level project of a shade in space. Also, we have the technology here and now for my proposed project.
Likes Baluncore
I've been giving some thought to painting my roof white at the moment...
Likes Oldman too and russ_watters
The advantage is that you, personally will benefit most. That sort of thing has universal appeal.
Well, how many square metres of roofing and/or rocks would need to be painted (and regularly repainted) white to have the same effect as the solar shade?
Likes russ_watters
And what would the solar shade cost to put up there? How big would the shade need to be, bearing in mind that it would not remain exactly on L1? All that space engineering would pay for a lot of ‘paint’.
By the time humans could engineer the shield, I reckon they would have solved climate change.
This white paint lark looks to me like it might be a bit counterintuitive.
Vegetation, crops or forest, increase the cloud, and to some extent increase rainfall. In Western Australia, the rabbit-proof fence marks the boundary between farmland and desert. Clouds tend to evaporate as they cross the fence line and move over the desert. Vegetation keeps the soil cool, which makes for more available water, and more ground cover.
Painting the town or desert white would tend to reduce clouds, so you would need to paint a greater area to compensate. Maybe if drought tolerant trees and shrubs were planted, we would be rewarded with clouds, and so not need all that paint.
Likes Bystander
So where will those clouds come from?
I suggested covering absorbent surfaces and nothing green. The ice caps are reducing in area so how else to get the net reflection back up.
It’s true that anything major could cause unintended other effects. White paint (or equivalent) would cause minimal disruption.
Of course, the obvious carbon zero behavior with much reduced consumption would not appeal enough to be tried by modern society.
I recommend, as a compendium of possible solutions to global warming, some more peaceful and, or realistic than others, the latest novel by Kim Stanley Robinson "The Ministry for the Future", the name of an imaginary UN organization set up to collect private groups, governments and UN proposals and test some of them to see if they are workable. Its creation and funding of several tens of billions of dollars is prompted by a disastrous heat wave in India that killed twenty million people.
No solar parasol in outer space is mentioned in this novel.
If we are discussing what might be unlikely solutions, there is the old one of putting large solar power collectors in orbit (I imagine also one could be on top of the sun-facing part of the parasol), this power to be beamed to Earth-side stations as radiowaves -- another idea that has been received with much the same skeptical criticism as the one of the parasol.
I had looked into this when I was getting a house built; the builder told me that in the heat & humidity of the Gulf Coast, the light roof would quickly become mildewed. In today's era of spray-foam insulation (far better than "cotton candy" insulation), I don't think it matters much.
I'm trying to imagine the liability issues the first time there's a blizzard. Especially if a school bus crashes on the ice. Think of the children!
Not without problems there. But a system with suitable ventilation would be best of both worlds. Relying on a hot roof to control condensation is a bad design approach.
I'm not sure what you are getting at. Evidence from the rabbit proof fence is only partial - not the PF way. There is more to it than just plants = clouds so no plants = no clouds. Transpiration of plants lowers the ground temperature. Reducing incoming level of solar energy would reduce equilibrium temperature of the ground. I am not suggesting painting green areas; it's the rocks, roads and roofs that I have in mind. Reflecting a percentage of the direct solar radiation will reduce mean surface temperature without reducing photosynthesis where it's needed.
I know the 'space based' solution appeals to people but this bubble could be a seriously blunt instrument which could cause totally unexpected changes to the environment. Until someone can cost the project it's a total unknown. Furthermore, if the bubble were to be built to withstand general wear and tear, it could be very hard to get rid of or modify in the not impossible situation where it's found to do more harm than good. to be honest, we have not proved to be good about climate management to date.
(Makes me laugh when they talk about terraforming Mars when they have pretty much failed down here)
FAQ: Could a bubble shield at L1 combat global warming?
Can a bubble shield at L1 effectively combat global warming?
There is no definitive answer to this question as it largely depends on the specifics of the bubble shield design and its implementation. However, some studies have shown that a properly designed and placed bubble shield at L1 could potentially reduce the amount of solar radiation reaching the Earth and thus contribute to mitigating global warming.
How does a bubble shield at L1 work to combat global warming?
A bubble shield at L1 would essentially act as a large mirror, reflecting a portion of the sun's radiation back into space. This would result in a decrease in the amount of solar energy reaching the Earth, potentially reducing the greenhouse effect and slowing down global warming.
What are the potential drawbacks or risks of using a bubble shield at L1 to combat global warming?
One potential risk is that the bubble shield could have unintended consequences on Earth's climate, such as altering weather patterns or causing imbalances in the Earth's energy budget. Additionally, the cost and feasibility of constructing and maintaining a bubble shield at L1 would need to be carefully considered.
Is a bubble shield at L1 a feasible solution for combatting global warming?
While the concept of a bubble shield at L1 has been proposed and studied, it is still in the theoretical stage and has not yet been implemented. Therefore, its feasibility as a solution for combatting global warming is uncertain and would require further research and development.
Are there any alternative solutions to combat global warming besides a bubble shield at L1?
Yes, there are many alternative solutions that are currently being researched and implemented to combat global warming. These include reducing carbon emissions, increasing renewable energy sources, and implementing sustainable land use practices. A combination of these solutions may be more effective in addressing global warming than relying solely on a bubble shield at L1.
15K
