Could a traffic jam in 1 road spread across all roads?
  • Thread starter caters
In summary, traffic jams can happen on both the streets and the highways, and they depend on a variety of factors.
caters
229
I have been in situations where low traffic leads in just a few seconds to a traffic jam both on the streets and on the highway.
https://tse1.mm.bing.net/th?&id=OIP.Mcb0d8b1940e2cf082bb67ef045975841o0&w=300&h=168&c=0&pid=1.9&rs=0&p=0&r=0
Traffic jam on street
https://tse1.mm.bing.net/th?&id=OIP.M835e36a3e28bd3c1f16ba7bada76f5bfo0&w=300&h=199&c=0&pid=1.9&rs=0&p=0&r=0
Traffic jam on highway
I most commonly see traffic jams on the highways and low traffic on the streets. But those traffic jams seem like they would lead to more and more traffic jams and spread across all the roads. However it is usually localized. I mean for example when I get home from Columbus State downtown, the first highway that comes up that I go on is I-71. This highway that goes from downtown Columbus to uptown Columbus always has some bad traffic but when going home from college, there is often a traffic jam on this highway. I get onto I-270 and there is no more traffic jam.
Why does the traffic jam not spread and cause more traffic jams and could a traffic jam spread throughout a network of roads no matter how widespread the roads are(city, state, country, continent)?
In reality all kind of results are possible as well as realized in certain conditions. So without any further specification there is no simple answer to it. The problem itself is subject to various fields of research. E.g. for the usual morning traffic jam, highways with a low average speed are still faster than roads of lower priority and often only subjective higher average speed. However, if there are special events, traffic jam might spread to all roads. One example I experienced has been the occasion of a solar eclipse which was expected to be best seen from about 100 miles south. So really many people added up to the usual already heavy traffic load and literally all south bounded roads had been overcrowded.
So the entire situation is really depending on many variables.
Traffic jams act like waves propagating through the road network. One car brakes (for whatever reason) causing the car behind it to break and the car behind that to break etc etc. You can see a very clear representation of it with this simple model (I advise playing around with the density and letting it run to observe traffic jams developing). A jam couldn't take out an entire road network though, not unless an inconceivably high percentage of cars were all traveling to the same place. Traffic jams become less of a problem the less cars they are and the further back a traffic jam goes the more potential off-routes it will pass. So you'll get more and more cars turning off either because that's the route they need to take or because they're avoiding it.
Likes StatGuy2000 and Drakkith
Ryan_m_b said:
One car brakes causing the car behind it to break
Only if it doesn't brake...:smile:
Likes davenn, mfb, jtbell and 2 others
Goddamnit.
Likes Bystander
It happened. Big evacuations are an example.
One interesting case was the total solar eclipse of 1999: The only one in Germany in the 20th century, and the only one in the 21st century will be 2081 - unless you want to take an airplane flight to hunt them, the 1999 one was a once-in-a-lifetime experience for many. Millions drove to Southern Germany to see it. And after the sun came back, millions wanted to get back at the same time. The north/south highways got traffic jams up to ~100 km length, the second-level streets (Bundesstraßen) got completely blocked quickly as well, and even some third-level streets got massive jams as people tried to avoid the jammed bigger roads.
Whom do you tell ... it was awful. Everywhere!
This is going back a while, but at one time I worked in London, which has a circular ring road (M25 motorway).
Most of the time it does what it's there for, distributing incoming traffic to the part of the city they want, and providing hubs for outgoing traffic.
When it messes up though due to an accident or something there can be complete chaos.
The motorway itself is jammed, and nothing much can either get in or out of the city, gridlock inside and outside.
It could take several hours for things to return to normal.
"All road intersections will be replaced with roundabouts, and you will start driving on the left. At the same time, you will go metric without the benefit of conversion tables. Roundabouts and metrication will help you understand the British sense of humour." (John Cleese)
Not only in Germany! We were on the highway Balaton-Budapest at the time.
Related to Could a traffic jam in 1 road spread across all roads?
What causes traffic jams?
Traffic jams can be caused by a variety of factors such as accidents, construction, rush hour, and road closures.
Can a traffic jam in one road spread to all other roads?
It is possible for a traffic jam in one road to affect other roads if they are interconnected or if there is limited alternative routes for drivers to take.
How can we prevent traffic jams from spreading?
To prevent traffic jams from spreading, it is important to have efficient traffic management systems in place, such as monitoring and adjusting traffic signals, providing real-time traffic updates, and implementing alternative routes.
Do traffic jams have a ripple effect?
Yes, traffic jams can have a ripple effect as they can cause delays for drivers and affect the overall flow of traffic in the surrounding areas.
Are there any long-term solutions to reduce traffic jams?
Some long-term solutions to reduce traffic jams include improving public transportation, implementing carpooling and ride-sharing programs, and developing more sustainable and efficient road systems.
